Old 03-20-2012, 09:03 PM   #1
06 Yaris
Drives: 2006 Yaris Hatchback 4DR
2006 Yaris noise in dash (like a speedo cable)
Hi every one. Just recently my Yaris has stated to make a noise in the dash. The noise kindf seems to be directly in front of the driver, only when moving. If the car is makeing the noise and you go to stop, the sound will be consistant till you get to about 10-15kmh and then you can gradualy here it slowdown till the car stops. Does not seem tempurature related. Yes I know the car does not have a speedo cable.
Thanks for any help
06 Yaris is offline   Reply With Quote
Old 03-20-2012, 09:23 PM   #2
If it is directly in front of the driver, it is most likely the electric power steering motor, especially with it being speed dependent.
Old 02-20-2013, 01:37 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im now noticing a slight whining noise during a slight turn.. if i keep the steering straight then no noise but slight turn i notice a slight whine.. never had that noise before..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 08-02-2015, 12:12 PM   #4
06 Yaris
I found my problem, just a plastic tie rubbing on the ground.
noise while moving
Is the 2006 Yaris Manual stick leather wrapped or not? hoahmaru General Yaris / Vitz Discussion 21 10-30-2008 08:14 AM
