Old 03-27-2012, 09:22 PM   #1
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Best tires psi?
I have 195/55/15 tires. What psi will be perfect on those tires???
Yaris_PR is offline   Reply With Quote
Old 03-27-2012, 09:44 PM   #2
TOLMACH
Drives: soarer
I actually have the same question for 205 40 17, please.
Old 03-27-2012, 10:08 PM   #3
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
take tire temps and adjust as neccessary. in my stock goodyears i run 54psi
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-27-2012, 11:49 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Temperature? What's the ideal range?
Old 03-27-2012, 11:56 PM   #5
sparkin88
Drives: 2010 Yaris 3D LB 5SD
All depends on what your doing.. What kind of tires/ what their rated at.
Stock tires. I'd say 38-40 front 36-38 rear for regular street use. Just my opinion.
But every tires different.
sparkin88 is offline   Reply With Quote
What is highest PSI in tires you have used? daf62757 Fuel Economy Forum 66 08-19-2011 12:43 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
