Old 03-28-2012, 11:04 AM   #1
yarismo
yarismo's Avatar
Drives: Yaris HB luna
can we install a button for ((P)) parking brakes
i wish to have a button in my yaris for parking brakes, instead of that handle, because i intalled an armrest recently which makes releasing the handle a little difficult.. i know this will require some modifications and special equipements. anybody taught about it already !!
yarismo is offline   Reply With Quote
Old 03-28-2012, 12:53 PM   #2
That would be a little tricky to do. Besides needing a fairly powerful solenoid to yank the cable, you would lose the ability to apply them gently (as you would need to do if you were using them in an emergency situation where the hydraulic brakes failed).
Old 03-28-2012, 12:59 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The big problem I see is that you would need something like the air brakes on a large truck. They are set up so that they are "on" when they are not pressurized, and "off" when they are pressurized. You would have to add an air compressor and a pneumatic cylinder that is strong enough to pull on the parking brake cable, in addition to the button and wiring. It could be done, but would be pretty expensive, and complicated.
The scary part of that is if it fails while you are driving, it will be the same as making an "e-brake" stop. If you have a manual transmission, just park with it in gear instead of using the handbrake. I don't use my handbrake at all because it can freeze stuck in the winter.
Old 03-28-2012, 01:02 PM   #4
CrankyOldMan
I wouldn't use an electric solenoid, because it would have to be constant-duty. Too much current draw when driving to be practical.
yarismo: Here's a link to what I'm talking about: http://auto.howstuffworks.com/auto-p.../air-brake.htm
Old 03-28-2012, 01:23 PM   #5
Our ebrakes don't work like truck ones, so the solenoid would only need to pull the cable to turn them on. Using a latching solenoid would allow them to stay pulled without power.
Old 03-28-2012, 01:49 PM   #6
CrankyOldMan
Aah, I didn't realize there were such things as latching solenoids. I was thinking that the only way to make it work would be either a continuous duty solenoid (drawing power when the car was off) or converting to a truck-like system by adding a spring to force the hand brake to be on by default, and turning it off with a pneumatic actuator when operating.
I'm still pretty green with my engineering skill set, so it's good to hear an alternative solution from another engineer.
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
max air conditioning button Idahotom General Yaris / Vitz Discussion 0 07-06-2011 09:41 PM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
