Old 03-30-2012, 08:57 AM   #1
brandypup
Drives: 09 Yaris
Dash light (!)
So this light is on. Seems to be the tires. Put air in one tire and the light went off but the next day the light is back on and tire is ok. I am getting oil change and tire rotation next month, could it be rotation time or something?
TIA
Connie
brandypup is offline   Reply With Quote
Old 03-30-2012, 09:39 AM   #2
bronsin
bronsin's Avatar
Not its not rotation time if the yellow tire icon light is on. The car is trying to tell you air pressure in one of the tires is low.
Maybe its another tire?
Check them again.
If the pressure is good (32 psi -35 psi) you have a car that means well but should shut up.
Tell us what happens!
Old 03-30-2012, 10:32 AM   #3
brandypup
Drives: 09 Yaris
thanks, I will check them this afternoon. I will keep you posted.
Old 03-30-2012, 01:39 PM   #4
brandypup
Drives: 09 Yaris
Yep 10lbs low same tire... off to look at tires. Thanks!
Old 03-30-2012, 01:44 PM   #5
bronsin
bronsin's Avatar
How many miles on the tires?
I think its possible you pickedup up a nail or something.
Which can be repaired (plugged) if the tire is not too old.
F/S Dash Light Dimmer Switch 1NZYaris1 Items for Sale by private party 4 09-26-2012 03:55 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
