Old 04-04-2012, 11:14 PM   #1
Hershey
Arrow Yokohama Avid Ascend low rolling resistant tires ..
http://www.yokohamatire.com/tires/detail/avid_ascend . Considering these for the '11 Fit which are 175/65-15 same size as the 2012 Yaris . They're also available for the '07 > '11 Yaris . Review of them at About.com , http://tires.about.com/od/Tire_Revie...vid-Ascend.htm . Here is what a few others are experiencing with them , http://priuschat.com/forums/gen-iii-...nt-review.html and http://www.bobistheoilguy.com/forums...2564841&page=2 ( bottom page 2 ) . Can get these for $120 each . Price includes mounting , balancing , and free rotation for life of tires .
Old 04-05-2012, 08:03 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
why do i think that sounds expensive? I love my yokohama tires.
Colin Chapman disciple
Old 04-05-2012, 09:01 PM   #3
thepartsmancometh
Drives: '08 LB, '07 WRX
I list the 175/65r15 for $105 ea through ford. This is for article # 32330. These tires are supposed to be pretty good, but I haven't put any on yet, so no firsthand knowledge. I wouldn't think they would be hard to find in the $95 range
thepartsmancometh is offline   Reply With Quote
Old 04-05-2012, 09:24 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
no 14" sizes. oh well, i'll have to see if any of the other eco tires have 14' sizes. has anyone seen any reports that these types of tires really help gas mileage?
Old 04-05-2012, 10:18 PM   #5
sickpuppy1
Drives: 2010 Yaris Sedan
http://www.tirerack.com/tires/tires....toModClar=Base
Mounting and lifetime balance for 11.50 at walmart
Old 04-05-2012, 10:45 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Interesting that they have a V rated version for what they are.
Old 04-06-2012, 11:40 AM   #7
09sedan
Drives: 2009 yaris sedan
wats better, the new Ascend , the avid TRZ or the touring S? which one would last the longest?
09sedan is offline   Reply With Quote
Old 04-06-2012, 10:04 PM   #8
Hershey
Tread starts at 12/32s . Think it's a 5year / 85,000 mile warranty and is T rated .
Old 04-07-2012, 09:02 AM   #9
thepartsmancometh
The ascend is going to be replacing the TRZ in most sizes. The TRZ hasn't been phased out yet, but it will be per our contacts at Yokohama. The TRZ is rated for 80k, the Touring-s for 65k. ALWAYS take all tire tread warranties with a grain of salt. seriously. The tire company can't control how you drive, or road conditions, so its tough for them to get EVERY SINGLE tire to last that long!
I haven't sold or installed any ascends yet, but the TRZ has always been a fantastic tire (especially for the price point). The touring-s is a decent fitment on our little cars, but I stay away from it on anything much larger. The sidewalls seem a wee bit "soft" and we see iffy wear on heavier vehicles; the softness can also be felt around corners as the tire "rolls." That being said, the TRZ and Touring-s I have sold 1.56 billion of (estimated ), with very few problems. Like with any other tire, fitment and application are KEY. The right tire for the right application.
As we see the ascend be more common I will comment about their construction, etc. but I assume that, being a Yokohama, they will be pretty good.
Old 04-07-2012, 09:11 AM   #10
thepartsmancometh
A lot of manufacturers are moving this direction. Many newer cars (even small ones!) are designed with higher speed rated tires when they setup the suspension. The speed rating is not just an indication of the sustained speed a tire can handle, it also represents the relative stiffness of that tire. The tires actually act as an additional spring in the suspension, so engineers have to design the suspension with a certain stiffness of tire in mind. If you go get a new 4 cyl camry (SPEED DEMON! ....not) it will most likely have v rated tires on it not because it can go that fast (yea right), but because the car needs that tire to have the suspension act correctly. If you got put an s-rated tire on that same camry it will
a) wear the tires very poorly
and
b) seem very soft and squishy, including response around corners. Its like the first time you put soft winter rubber on your car instead of fancy summer tires.
Old 04-07-2012, 12:19 PM   #11
toad
toad's Avatar
Drives: street-legal go-kart
i've had both the trz and touring-s on our yarii and liked them both, however, the trz had an abnormally large center channel that would get rocks stuck in all the time. it drove me nuts hearing the little 'clicks' at low speeds constantly!
toad is offline   Reply With Quote
Old 04-07-2012, 11:50 PM   #12
Hershey
Here's a review of the Ascends posted yesterday from an owner of a Subaru Outback . http://www.subaruoutback.org/forums/...id-ascend.html . Likes them alot .
Old 04-09-2012, 08:21 PM   #13
thepartsmancometh
true, we've had a few people gripe about this. The overall quality (and price point) of the tire seems to override this issue for most folks, but I had one guy INSIST on a different tire because of this. It's OK, just sold him Michelin Harmony instead .
Old 04-09-2012, 11:21 PM   #14
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive been curious about these tires as well. Ill be needing tires aoon and cannot decide to stay stock or go up to 16s...
Ive been eyeing up the toyo extensa...great price and seems to have a decent blend performance and rolling resistance
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-10-2012, 11:10 AM   #15
Hershey
We noticed the TOYO Versado Eco tires as well . http://toyotires.com/tire/pattern/ve...l-season-tires . The 175/65-15 start at 9/32s . All others begin with 10/32s .
Old 04-10-2012, 12:56 PM   #16
33OH
Drives: '08 Yaris
Depending on the treadwear, it really doesn't matter how much tread you start with. Kind of like bragging about having a bigger gas tank but getting less MPG's. :)
And I can get you those Yokohama Avid Ascend's for MUCH cheaper than $120 each.
Old 04-10-2012, 10:53 PM   #17
Hershey
The Ascends are $93 each before tax . The $120 each includes mount and balance of each tire . Been calling around and the $93 is the best thus far . One quoted $118 , not including the mount / balance . Leaning towards the Bridgestone Ecopia 422 at $81 each and a $70 American Express card from Bridgestone that would cover the mount and balance of 4 tires . This offer expires 4/29/12 .
Old 04-11-2012, 06:57 AM   #18
33OH
Drives: '08 Yaris
Ah didn't realize you were including mount/balance, was going to say - at $120 each for Ascends you're paying well over retail for those.
I think the Ecopia's are a great deal - especially with the $70 gift card that Bridgestone is offering.
That's also a great price at $81 each - actually beats my wholesale price directly from Bridgestone themselves. (I'm at $91.50 each retail on that tire.) Will have to call them about that. :)
FS: ALMOST new Yokohama Winter tires with 1.6EL turtle wheels - TORONTO Riced-yaris Canada 8 11-21-2010 05:41 PM
Yokohama Orange, You Glad? Yar Is Word Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-24-2010 09:29 AM
WTB Stock 15" tires low miles POORSHA Willing to Buy by private party 0 04-19-2009 12:03 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
