Old 04-12-2012, 09:23 AM   #1
greg86m
Drives: 07 yaris
humming noise
I'm a noob and so this could be a simple question but I have an 07 sedan and for a few months now (ever since I put new tires on it) there has been a significant humming noise coming from what seems to be the rear of the car.
the noise is most prevalent between 25-35 MPH. I have noticed that especially when turning right like on an on ramp when I am going 30 ish mph the noise goes away until I straighten out again.
I thought it was just road noise from the new tires until i realized it didn't change on different types of pavement and such. My only guess is the rear hubs could be bad but I would love any insight before I spend a bunch of money
thank you!
greg86m is offline   Reply With Quote
Old 04-12-2012, 10:54 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
troubleshoot everything you can yourself, like take the front wheels off and try to rattle the calipers/rotors with your hands. If they are loose and can move laterally, you've found something that need tightening. The rear may be more difficult, but checking the front will take very little time :)
Old 04-12-2012, 03:19 PM   #3
746watts
Drives: 2014 yaris hybrid
I have that noise too and I jacked up each wheel and spun them by hand, the left hub is the culprit, the right one is silent. No play in the bearing yet but it's making an unhappy hum/rumble. Sounds like you may have the same problem. You'll know for sure if you jack up each side and spin the wheel. If the bearing is on the way out it will be shouting at you.
746watts is offline   Reply With Quote
Old 04-12-2012, 09:44 PM   #4
greatcar
Drives: blazin blue pearl hatchback
you guys have bad wheel bearings you need to have them replaced
greatcar is offline   Reply With Quote
Old 04-14-2012, 03:27 PM   #5
greg86m
Drives: 07 yaris
that's kind of what I was afraid of...is it difficult at all to change the rear hub/bearing assembly? I've found some for around $180 ish, does that seem like a decent price for the whole hub assembly with ABS?
Old 04-14-2012, 08:32 PM   #6
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
The rear assembly is easy to change - I wouldn't cheap out on a wheel bearing though. Moog ($224 CAD) or SKF ($204 CAD) are good aftermarket OEM clones. Toyota's are over $300 CAD.
devinlamothe is offline   Reply With Quote
Old 04-14-2012, 10:15 PM   #7
Happy Little Pony
Drives: 2007 Yaris HB
It could be a bad tire. Rotate the tires and see if the noise changes location. It's a long shot, but doesn't cost anything to try.
Also, did you make sure the lug nuts were tight? If the tire shop didn't torque down the lug nuts, you might have a loose wheel that is vibrating. Very dangerous, but easy to fix.
Happy Little Pony is offline   Reply With Quote
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 08:27 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
