Old 04-13-2012, 03:28 AM   #1
roneezy360
roneezy360's Avatar
Drives: Toyota Yaris 2007
Rear Allignment on Hatchback 07 Yaris
I recently had an Allignment about a month ago and noticed my rear tires were still crooked. I didnt care at the time but I've been driving my Yaris for about 1-2 Years and I can actually feel every bit of movement when driving my baby. In the streets its fine but when im in the freeway hitting 70-80mph I feel crooked going straight and tend to go a bit to the left and right and after looking at my rear wheels my left rear seems to be facing the engine a tiny bit while my right rear is facing my engine a lot more than the left.
I know shops dont usually mess with the rear only with the front but what should I do? I want my rear straight and fixed not only because this bothers me mentally but also because its uncomfortable to drive. Im going to go to the shop tomorrow, can anyone hand out advice on what to do? What to say?
I just want this problem fixed lol.
roneezy360 is offline   Reply With Quote
Old 04-13-2012, 10:39 AM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
most shops wouldn't even think to look at the rear wheels on a fwd car. Find someone with a great laser alignment machine and have them do a 4 wheel alignment. Just let them know you think the rear is misaligned and they should take care of it.
Colin Chapman disciple
Old 04-13-2012, 11:25 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
last time i check rear cannot be adjusted..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 04-13-2012, 12:22 PM   #4
I could swear this is a second thread about the same thing. I believe you were asked before if you got a four-wheel alignment.
If you do, it will show with a printed copy what the settings were before and what they adjusted. Posting it here will result in better replies.
You can also post pictures of your car showing the crookedness in the rear, since it is apparent to the naked eye.
Old 04-13-2012, 12:35 PM   #5
why?
why?'s Avatar
Drives: Yaris LB
it isn't fully adjustable, but that does not mean it cannot work its way out of alignment. Or that something could not simply break.
Old 04-13-2012, 02:47 PM   #6
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
http://www.spcperformance.com/index....c&task=details
heres jus one brand of a wachamacalit that will help fix the thingamabob on dat thar doohiky
OTA'sTOY is offline   Reply With Quote
Old 04-13-2012, 03:41 PM   #7
TOLMACH
Drives: soarer
i think rear wheels can be adjusted using shims.. it is better to find a place that specializes in wheel adjustment
Old 04-13-2012, 07:08 PM   #8
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
The rear is considered non adjustable, however you can dial it in if need be. I used feeler gauges http://www.google.com/search?q=feele...iw=768&bih=518.
While it is on the alignment rack, you loosen the 4 bolts holding the hub and slip the gauges in as needed ( in between the torsion beam flange and hub). It is time consuming though... And expect to pay more than the
standard alignment rate. Also, I doubt any normal shop would even do this... Your best bet it to bring it to a performance shop.
Ptuning.com
Old 04-14-2012, 01:06 AM   #9
Viperoni
Drives: 2005 Toyota Echo
This is how you properly align the rear wheels on an Echo/Yaris (and obviously a Prius as well):
http://priuschat.com/forums/gen-ii-p...ment-shim.html
My alignment guy, who also aligns winning race cars, took my car from almost 0 camber and -1/2* toe in to -1.5* camber and 0 toe.
2006 Saturn Ion Redline
Old 04-14-2012, 02:30 AM   #10
feeler gauge trick is pretty cool, thanks for that
Old 04-14-2012, 10:09 AM   #11
why?
why?'s Avatar
Drives: Yaris LB
now that is the type of alignment place i want to go to. I'll pay a little more for someone who knows what the hell they are doing and knows how to use bolts and shims to perfect the alignment.
Old 04-14-2012, 05:28 PM   #12
roneezy360
roneezy360's Avatar
Well I went to a few shops and they said they couldnt adjust the rear. So i dont have a choice but to find a performance shop soon.
Old 04-14-2012, 05:59 PM   #13
90tsi
90tsi's Avatar
Drives: 09 yaris
The rear is adjustable with a shim I thought.... I've installed several in fwd cars. My alignment machine at would will ask for the brand I'm using and print a trimming template accordingly. Any decent place should offer or tell you about that....
90tsi is offline   Reply With Quote
Old 04-14-2012, 06:14 PM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
We sell those round shims... But they are really a big trial and error. You can't do it with the alignment targets on the wheels because you have to keep removing the hub if you have to reset the shim. I also don't like the fact that it is a composite/ plastic. So over time it will compress and the hub bolts can loosen. I came to use the feeler gauge technique instead. Of course it is my preference, but just saying.
Ptuning.com
Old 04-14-2012, 06:25 PM   #15
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
metal parts vs plastic for suspension, I would trust the metal over plastic. feeler gauge or make your own shims. even when i worked on howitzers we used brass shims so trusting metal makes more sense. I would have to test a plastic and see how it hold up before I go to all the trouble of calling it good or trusting it to last.
Old 04-14-2012, 08:18 PM   #16
Viperoni
My alignment guy aligns winning race cars this way... it probably works just fine ;)
http://canalignment.com/align.html
Old 04-15-2012, 01:43 PM   #17
90tsi
90tsi's Avatar
Drives: 09 yaris
I haven't had any issues with the composite shims yet. Asfar as the trial and error my alignment machine prints off a pattern I can cut the shim to. Its not surgical but it get has been getting me in spec. But I've had it for a month or so.
Old 04-15-2012, 09:17 PM   #18
Viperoni
Also, FWIW, I haven't melted mine after 5 track events... but the drums on the rear dont get very hot. The front wheels and lug nuts get so hot I sometimes have to wait 30 mins to take them off.
WTB: stock yaris hatchback rear speakers Adriaan Willing to Buy by private party 9 09-21-2011 10:23 AM
FOR SALE 2009 Toyota Yaris Hatchback (Leesburg, VA) djscandal Mid-Atlantic 0 06-28-2011 12:16 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
