Old 04-13-2012, 02:54 PM   #1
yredgt
Drives: 1.5L SuperRed Yaris (TS)
Correct Oil Pressure??
Today I finally completed the oil press. gauge install. I just wanted to know what pressure readings are correct or what should be the correct range.
The gaunge that I installed is a mechanical one, not an electric with a sender.
My current readings are:
1- Around 75 P.S.I. idle speed
2-85 PSI @ 2000 rpm
3-100 PSI @ 5000 rpm
I believe that these reading are TOO high!
Can anyone help me? Since I have no idea on this readings.
Video of the gauge when operatng.
http://www.youtube.com/watch?v=XqMpH...TMTzoCoECb5bM=
yredgt is offline   Reply With Quote
Old 04-13-2012, 03:42 PM   #2
seems pretty normal to me. what is your idle pressure cold and hot? should be lower when hot
Old 04-13-2012, 05:23 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I have an electric(Autometer) gauge hooked up to a an oil filter sandwich adapter and I get the following(roughly) on 20-50 Valvoline VR1 dino
Cold(coolant temp of >180deg)
Idle 20-40
5,000(ish) 80-100+(the gauge blinks @ 100)
Warm(+185deg coolant)
Idle 7-20
5,000(ish) 75-90
Coolant reading are pre-radiator and are generally +7-10 above the Scangauge...wherever it gets it's info from.
-Type 07 FFL-
My odometer 03/11
Old 04-13-2012, 05:55 PM   #4
yredgt
Thank you for your info.!!! I was starting to worry but since my gauge is not a very expensive/accurate one, your readings are pretty much the same as mine. After an hour of constant driving the idle pressure drops to the 40 - 45 PSI range. Also when hitting 2000 rpm's it drops to the 75 - 80 PSI range.
