Old 04-16-2012, 07:06 PM   #1
kz27
Drives: .
tire recommendations - 2010 yaris
Anyone have a good recommendation for the next set of tires? I have a 2010 Yaris with 36K miles, and the OEM tires are going downhill fast, thought there was more life in them. Came stock with 185/60R15s. Looking for affordable, quiet, comfort, reliable. Are there any standouts for the Yaris or is it hit or miss. I am in the desert with heat extremes in the summer and potholed city roads. When I read reviews online, it seems like for any tire there are lovers and haters. And do the tire pressure sensors need replacing with a new set or is this a myth to up the price? Thanks!
kz27 is offline   Reply With Quote
Old 04-16-2012, 07:35 PM   #2
Replacing sensors is a myth that I personally have never heard of.
Did you search 'tire recommend'? You will see that responses can eventually leave you with about as much clarity as online reviews.
Old 04-16-2012, 07:39 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The sensors are only changed if you get custom rims that will not accept the OEM sensors. My tire requirements are almost in the opposite direction: sticky and wide; noise, comfort and price are secondary. That said, when I bought mine, it had Bridgestone Potenza RE92's in 185/60R15 (OEM size). They were quiet and dependable, with decent all season performance.
Old 04-16-2012, 09:03 PM   #4
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I just got a set of Hankook Optimo H727. 100,000 mile tread warranty, less than $100/tire, and great reviews. I have no complaints so far, and they seem to be a fine all season choice.
goliath1812 is offline   Reply With Quote
Old 04-16-2012, 09:39 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
I would replace with 195/60/15's. These have had great reviews, and some yarisworld members have provided very good feedback: http://www.discounttiredirect.com/di...w=false&cs=195
Old 04-16-2012, 10:22 PM   #6
CrankyOldMan
That would be a little larger than stock. Why not 195/55R15?
Old 04-16-2012, 11:07 PM   #7
Hershey
Highly suggest the Continental Pro Contact w/ Eco Plus . Have these on the '08 sedan and the ride is better , noise level lower , handling ( especially wet ) is better and fuel economy remains the same as with the Bridgestone RE 92s ( O.E.M. ) . These were originally bought for the 2010 3 door we had ( traded in ) and made a world of difference over the Eagle LS as well . See pics of those on 2010 , http://www.yarisworld.com/forums/showthread.php?t=31293 , post # 17 . Keep them at 35 > 37 p.s.i..
Old 04-16-2012, 11:23 PM   #8
Hershey
FORD has a $100 discount on Continentals and other brands of tires until May 31st , http://owner.ford.com/servlet/Conten...iceCouponsPage . A year ago we bought them for $93 each ( pre-tax ) , if I remember correctly . So , should be able to get them for under $70 each ( excluding tax , etc. ) . Wish that was available then . Here they are at Tirerack for $79 each , http://www.tirerack.com/tires/tires....utoModel=Yaris Liftback&autoModClar=3-Door . Let us know what you decide on and how the tires work out for you . Good luck .
Old 04-16-2012, 11:33 PM   #9
Hershey
We can thank thepartsmancometh for pointing out the $100 discount from FORD . He's truly our saviour ( of money ) .
Old 04-17-2012, 12:30 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
there are tons of cheap inexpensive tires out there that will last forever. That $100 discount sounds pretty sweet.
Colin Chapman disciple
Old 04-18-2012, 06:51 AM   #11
33OH
Drives: '08 Yaris
I always recommend the Hankook Optimo H727's. 100,000 mile warranty, great performance in rain/snow/dry. I've ran two sets of them and personally love them.
I can get them to you for $312 shipped ($78/tire shipped).
Also, with the tire pressure sensors - just check the rubber gasket that seals it to the wheel. If the rubber is cracked or getting stiff - it needs replacing. But the whole sensor only needs replaced if it fails. The gasket (also called a TPMS rebuild kit) shouldn't cost you more than $5 per tire. I can get them to you for less than that.
Old 04-18-2012, 07:29 AM   #12
goliath1812
Great price. I only got my set from discount tire direct through ebay because they were also giving away a $100 Visa prepaid card, bringing the total purchase to $240.
Old 04-18-2012, 08:05 AM   #13
33OH
Drives: '08 Yaris
Thanks, Goliath! That was a great deal when they had it going on!
2010 yaris tire recommend
2010 Yaris Stereo Install Help FPG In Car Entertainment + Electronics (audio / video / alarm) 13 04-21-2012 09:16 PM
Vital info for prospective 2010 Yaris buyers YarisOwnersDad New YARIS Purchase Forum 22 05-19-2010 09:16 PM
