Old 04-22-2012, 01:48 AM   #1
grinya202
Drives: yaris hatch 2006 d4d
16`dezent
6.5*16 et45, 205/50r16.
When turning the steering wheel to the right until the end of a little catchy, but right there. Why is it so? Thank you.
grinya202 is offline   Reply With Quote
Old 04-22-2012, 11:29 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I think you're asking "why are my tires rubbing?"
Those tires are both wider and taller than stock tires:
Adding wheel spacers might help, but only if the tires are rubbing on the inside of the wheel well. If they are rubbing on the fender, then you need smaller tires, like 205/45R16 or 195/50R16.
Old 04-22-2012, 12:52 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
You've just been schooling people all day with those offset calcs lol
Old 04-22-2012, 12:53 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/50's on 16x6.5, ET45 is an excellent fitment for your car. It's common for 205's to rub a tiny bit on the plastic fender liner at full lock. It's nothing for concern.
Old 04-22-2012, 03:53 PM   #5
CrankyOldMan
rimsntires.com is your friend. =)
Old 04-23-2012, 05:13 AM   #6
grinya202
I asked why the catches by turning in one direction, while the other does not cling. What is a tire calculator I know, thank you.
Old 04-23-2012, 11:49 AM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
because one way it just catches the edge of the plastic fender lining. The other way the fender lining might not be as big, or it could have been bended out of the way by something. If Kimona says it is all good, then listen to him. He's the tire guru.
Colin Chapman disciple
Old 04-23-2012, 01:30 PM   #8
grinya202
Thank you very much!
