Old 05-08-2012, 05:20 AM   #1
Dperry
Dperry's Avatar
Drives: 2007 black yaris hb
dropped, slammed, stanced, layen frame
hey this is for you out ther who r super low and at the point of rolling and pulling fenders. what happends to the fender liners? do u guys completly remove them or is ther an aftermarket that im not aware of. i plan on getting coilovers this summer and gettin as close to the earth as i can. so just lookin for some pointers
Dperry is offline   Reply With Quote
Old 05-08-2012, 09:41 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
If you pull those liners completely your engine is going to take a thrashing from all the dirt/water that is goin to get pulled up into the bay while you drive...I put my fenders back in because of that. It made it impossible to keep the engine clean.
If you never pop your hood it won't matter so much.
-Type 07 FFL-
My odometer 03/11
Old 05-08-2012, 10:07 AM   #3
33OH
Drives: '08 Yaris
I just left mine in, as mazilla said - all of the road grime/grit (and salt here in Ohio) goes right to your engine with them out.
Old 05-08-2012, 11:33 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I rolled my fenders. And cut the top out of my liners. Yes, rocks get shot up where the hood hinges are, thats the most I have seen. I would take an air blower every other weekend and blow most of it out.
-Derrick-
Old 05-08-2012, 11:51 AM   #5
Dperry
Dperry's Avatar
ok so if i go this rout it wont be driven in bad weather anyway but i can get away with just cutting rub points out?
Old 05-08-2012, 12:44 PM   #6
Mine used to rub, I just let it rub for a bit to get an idea of where it rubs, then I cut out the areas. Really reduced the rubbing.
Old 05-08-2012, 02:16 PM   #7
ilikerice
ilikerice's Avatar
^Yea.. basicly what I did also.
-Derrick-
Old 05-08-2012, 02:35 PM   #8
33OH
Drives: '08 Yaris
^ Me too.
Old 05-08-2012, 04:41 PM   #9
mazilla
advocatus diaboli
mazilla's Avatar
^ same here, although i left them long enough that they basically worked themselves out.
-Type 07 FFL-
My odometer 03/11
Old 05-08-2012, 08:36 PM   #10
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
:respekt
Sup kaotic... i just bought some lowering springs at toyotafest thanks jeff@microimage.. BUt question was how low are you kaotic the springs i got are b&g 1.4 front and back... going to install as soon as my next paycheck comes around can't wait.... also sup Maz... so soryy to hear u dint win any prize at toyotafest ur yaris is pimped out props maz and thanks for the pointers got some good ideas for future mods....
g.q.vios is offline   Reply With Quote
Old 05-09-2012, 01:16 AM   #11
Originally Posted by g.q.vios View Post
:respekt
I have the Tein S.Tech's. So on the sedan, they lower it 2-2.1" all around. I did, however, install spring coil spacers in the rear, so it's ~.2" higher.
Old 05-09-2012, 05:04 AM   #12
YAR1S
YAR1S's Avatar
my coilover/wheel setup tore gashes in my liners.... left them in... figured it was the car trying to improvise... another thing... my wheels broke all the fender clips/fasteners... oh well... not needed. ;)
-Jen <3
Old 05-09-2012, 06:58 AM   #13
Dperry
Dperry's Avatar
im on tein s tech springs and wen i had my winter tires on they pretty much chewed up my fender liners so as of right now i think theres only a couple fasteners holding them in
Old 05-10-2012, 09:38 AM   #14
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
g. q I would install them yourself it will save a lot of money
Old 05-10-2012, 10:54 AM   #15
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
if you are only lowering 1.4 you shouldn't have much problem unless you aftermarket rims and tires are a good bit larger in total diameter than the factory set up. I'm lowered 1.8 but I am using factory size tires and do not have any rubbing issues unless I have a friend weighing me down in the back seat. there should be a thread here some where that list the total diameters of some of the common size aftermarket tires and it tells you how much over factory specs they are.
