Old 05-13-2012, 10:42 AM   #1
wajeehr
Drives: Toyota Vitz
Speedometer problem
Hi guys,
i have 2008 japnese yaris its speedometer gives speed in miles can it be changed in km ??
i heared that there is some computer installed in car but i dont know how to access it ..
kindly help me out
thanks
wajeehr is offline   Reply With Quote
Old 05-13-2012, 11:06 AM   #2
The Japanese digital speedometers are KM only. Some of the European digital ones can be switched between KM and Miles. The easiest and least expensive solution would be to purchase a US one (which can be purchased off ebay for $50 to $100) and install it in place of the existing one. The main computer (ECM) actually deals in just KM, so it doesn't care about how the speedometer displays it, so just the speedometer needs to be changed.
If you car is a right hand drive one (which I assume it is), then to switch from a Japanese cluster to a US or European one you will have to lengthen the two cable that plug into the it, since on the Japanese clusters the connectors are on the opposite sides and the wires are not long enough to reach.
Old 05-13-2012, 04:02 PM   #3
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Could I put a digital one in my Canadian one ? :O
Interior:ALL red, black roof
Old 05-13-2012, 09:50 PM   #4
Yes. I have a European LHD digital one that I bought from a junkyard in Israel (via ebay) to experiment with.
Old 05-14-2012, 02:40 PM   #5
packetrace
packetrace's Avatar
Is it a sedan one ? If yes i buy!
Old 05-14-2012, 03:05 PM   #6
There are no European sedans, only liftbacks are available there (and made in France).
Old 05-14-2012, 03:10 PM   #7
packetrace
packetrace's Avatar
So i wont be able to have the digital one ?:(
Old 05-14-2012, 03:13 PM   #8
No. Even if the Belta gets the digital one in Japan, it will be pointed in the wrong direction, so you would only be able to view it from the passenger seat.
!! Speedometer Needle Problem !!! Murtaza_murti Cosmetic Modifications (Exterior/Interior) 40 11-25-2014 11:48 AM
Warrany Service Problem? 2009Yaris General Yaris / Vitz Discussion 4 03-31-2011 05:56 PM
Problem with my car rakhan01 DIY / Maintenance / Service 8 12-03-2010 06:12 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 02:30 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 09:11 PM
