Old 05-14-2012, 08:40 PM   #1
TPA5
Wait, what?
Drives: NULL
Tire Pressure Gauge?
Hey all,
Just wondering what tire pressure gauges you folks recommend? I just have a cheapie one and I want to make sure I'm getting accurate readings, so I want to buy a new one. Which ones do you guys use/recommend?
TPA5 is offline   Reply With Quote
Old 05-14-2012, 09:35 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
mine is a round dial style but it only goes up to 60psi so you can really see where you are. not a big fan of the digital ones. I have seen the one like I have shaped like a tire (has a little rubber boot around it with tread on it...cheesy)
Old 05-14-2012, 09:40 PM   #3
racerb
While not the exact same gauge I use, this is almost identical to it and I've actually got 2 of them. One of them has the rubber bumper around the gauge itself, the other which is much older, I cut and placed part of a can cuzzy around to protect it. I prefer the 0-60 versions, cause thats the normal range I'm working within!!
https://www.pegasusautoracing.com/pr....asp?RecID=344
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-14-2012, 10:14 PM   #4
BEEF
BEEF's Avatar
several of my friends run e rated tires (80psi) so they can't use it. big trucks are cool.
I still prefer the 60psi one. lets me put mine to 50ish without issue. that is on my other car. not even sure what the yaris has in it (I need to check that)
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 03:06 AM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 05:13 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 11:17 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
