Old 05-19-2012, 03:11 AM   #1
jens07yaris
Drives: 07 yaris
07 yaris wont start
okay here is the problem. my friend was driving home from work. it just bogged out then died.it would not startback up.anyways the fuel pump was not coming on. so i changed it. i can hear it come on. but it wont start. i spray starting fluid and it will run. i hit the gas pedal and it boggs and dies out. ive noticed the key will stay on when i turn it could it have burnt out the e c u or i c m i turn the key and let it go and it will still be turning over. any advice would help greatlly thank you
jens07yaris is offline   Reply With Quote
Old 05-19-2012, 06:44 AM   #2
It sounds like the fuel pump is running, but the injectors are not. Check the AM2 fuse in the under hood fuse panel, as that one supplies power to the injectors.
If you turn the key and let it go and the starter continues to crank, then the ECM is alive, since it takes the key bump as an input and does the cranking until the RPMs climb when the engine fires.
Old 05-20-2012, 12:02 AM   #3
jens07yaris
Drives: 07 yaris
okay i will try it thank you. ill re post the results.....
okay i checked the fuses all good. really stumped. code reader no codes
Old 05-23-2012, 03:40 PM   #4
jens07yaris
Drives: 07 yaris
so the fuses where all good. checked the injectors they are getting power. where can i get a repair manuel free,if possible. i am starting to think the x boyfriend did something to it. but i need to look at pics of fuse box, underhood fuses and relays, to see if something is missing or the wrong relay is in the wrong spot. i dont know.im kinda old school, i know more about muscle cars. thats what i grew up around. im learning about all this new computer cars. so thank you for your time and your posts.
Old 05-23-2012, 03:47 PM   #5
Nothing worse than a scorned X.
You can download the service manuals from the Micro Image Forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
Reading your first post again, since it happened while driving (and since there is an X involved), I would suspect that whatever killed the fuel pump may have also plugged the injectors. When you changed the fuel pump, did you empty and clean the tank?
Old 05-25-2012, 01:58 AM   #6
jens07yaris
Drives: 07 yaris
yes cleaned the tank.the injectors are getting power. its just weird that it will run when i spray starting fluid in it.but if they are getting power dosent mean they are spraying gas right?
Old 05-25-2012, 06:23 AM   #7
Not necessarily. Injectors aren't pumps, they are merely solenoid valves, so when they get pulsed the valve opens letting the fuel pumps pressure push the fuel through. If they are clogged nothing will happen when they are pulsed. You can actually pull them and spray cleanser through it while powering it with a 9 volt battery to test/clean them.
Old 06-04-2012, 03:12 PM   #8
jens07yaris
Drives: 07 yaris
thank you i will try that.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
Let's start a Yaris Club, each member has a specific number decal Yawesh General Yaris / Vitz Discussion 48 04-10-2009 10:49 PM
