Old 05-21-2012, 10:46 AM   #1
razingman
Drives: 2007 ls liftback 5 door manual
Quick question about setup
So all I have right now is a and one pair of hertz esk-165s. I have a 2007 liftback, now do I actually need a harness and dashkit or is that just something to make it look pretty? I plan on getting an amp and sub later and not having any rear speakers.
razingman is offline   Reply With Quote
Old 05-21-2012, 11:52 AM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Think you left out some info. Are you adding a headunit as well ?
If so you need a wire harness and a dash kit.
SqComp can probably give you more info on them Hertz.
Old 05-21-2012, 01:51 PM   #3
razingman
Yes, forgot to CP it in, dumb me.
It's a AVH-P1400DVD double din.
Why do you need the harness?
Old 05-21-2012, 02:20 PM   #4
_S7V7N_
_S7V7N_'s Avatar
Okay a bit of research will need to be done for the dash kit for a double din Unit.
One end of the harness connects to your factory connector and the other end with the wires is color coded to connect to you aftermarket radio harness.
Here's a pic of the back of that unit and the wire harness that connects to the harness listed above
Old 05-21-2012, 06:03 PM   #5
razingman
Got it, for tweeter placement, do you think on that front dash top of the window , bottom of the window or on the pillar would be best?
Old 05-21-2012, 06:07 PM   #6
razingman
Okay, got it, thought the connectors in the back were just the exact same cables.
Old 05-21-2012, 06:36 PM   #7
_S7V7N_
_S7V7N_'s Avatar
SqComp can probably better guide you for placement. What I would recommend is an amp for that component set. I don't think they'll reach there full potential off the headunits power.
Old 05-21-2012, 08:00 PM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
So you've got the 6" Energy component set?
The tweeters will help stage height if they're up in the pillars. As far as aiming, look for a spot as close to the glass and more on axis since they're a smaller 20mm format and you're probably using the crossover that comes with the set.
― Thomas Paine
Old 05-21-2012, 09:18 PM   #9
_S7V7N_
_S7V7N_'s Avatar
What about powering them puppies up Sq ? What do you recommend ?
Old 05-21-2012, 09:57 PM   #10
razingman
I was thinking of getting an amp in a couple of weeks when I have the money for a great one and a sub, I care more for quality then noise
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 05:14 AM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 08:51 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
quick air filter question wingdood DIY / Maintenance / Service 3 05-11-2009 08:17 PM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 05:38 PM
