Old 05-27-2012, 04:03 PM   #1
vten
possibility to do hub conversion from 4x100 to 5x1XX
is it possible to change the original wheel hub on this yaris to a 5 lugs one ?
it's easier to use a wheel adapter to make the conversion, but it's PITA to find wheels with a really high offsets ..+50 and up ...
here's my all time favourite wheels :
http://i964.photobucket.com/albums/a...0/HPIM0196.jpg
any input ?
Old 05-27-2012, 04:08 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
In theory the xD hubs can be swapped, but I don't know if anyone has successfully done it.
Old 05-27-2012, 04:30 PM   #3
CrankyOldMan
Let's take a look at villagescionparts.com and toyodiy.com to see what the part numbers look like...
The rear beam assembly is the same on the Yaris and xD, so the rear hubs should be a direct bolt-on. The front steering knuckle is also identical, but the drive shafts have different part numbers. It's possible that they're different spline patterns, but it could just be a different diameter or length.
Looks like it's do-able with a drive shaft swap, since the transmission and differential are identical on the Yaris/xD. Not cheap, even through a salvage yard, but if you're really set on those wheels, it may be your only choice...
Old 05-27-2012, 05:26 PM   #4
vten
thinking more to an european hubs ...either 5x112 or 5x120 ...or maybe 5x114.3 ...just a thought ..
Im pretty sure itll be over at least $1K project :(
Old 05-27-2012, 06:20 PM   #5
CrankyOldMan
I guess that would fall into the category of "buy, test, fabricate and report." The alternative is to contact the manufacturer and see if they will do a one-off of the style you want in a 4x100 pattern. If they are in fact 2- or 3-piece wheels, it would be much simpler to have a new center produced than a whole gravity cast or billet wheel machined.
Old 05-27-2012, 07:33 PM   #6
vten
something like this :
http://www.ebay.com/itm/240SX-5-Lug-...ht_3076wt_1163
but it conversed from 4x114.3 to 5 lugs ......
poor us 4x100 ppl :(
Old 05-27-2012, 07:41 PM   #7
You could use a set of these:
http://www.urotuning.com/Wheel-Adapt.../402245571.htm
Old 05-27-2012, 07:44 PM   #8
vten
yup, but its hard to find a wheel with a high offset with that 20mm adapter ....must be over +45 or higher ..
Old 05-27-2012, 11:17 PM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
there could be plenty of reasons other than the wheels to upgrade to a 5 bolt that would make it worth it?
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
