Old 05-30-2012, 08:07 AM   #1
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
High Temp Light
Mga Kabayan,
Akoy tumatakbo ng 110KPH nag biglang umuilaw ung Temp Light (ReD) at nag-rev yung makina tapos bumaba speed. Binitawan ko yung acceleration sabay apak at nawla naman. Diretso lang ako takbo siguro after mga 1 km umulit ang pangyayari at same thing din ginawa ko. Nakakita ko ng gasolinahan at ipinark ko muna ang tsikot. ok naman lahat umaandar yung FAN, may Coolant naman. nakarating ako ng Batha ng di na umulit ang pangyayari. Umuwi ako ng 11pm at wala namang nangyari. Bukas AC ko.
Ginamit ko kaninang umaga at wala naman nangyari.
tiningnan ko yung Battery terminal at nilinis at hinigpitan ko... wala naman mga namuong acid stains.
Any options???? ok naman yung flow ng tubig sa Radiator.
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 05-31-2012, 01:52 AM   #2
syntax
syntax's Avatar
wala pa nakaka experience nyan pre' as of now ok pa? hindi na nagyari ulit? sa speed na un lang ba nangyari un?
Old 05-31-2012, 02:32 AM   #3
BoyMalambing
As of now di na nangyari since umuwi ako kahapon at pumasok ngayon.....
Old 05-31-2012, 09:52 AM   #4
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Umilaw yung High Temp light ko ng dahil sa fuse ng blower fan.. Umilaw lang ito pag overheat na yung engine.
Check mo yung cooling/blower fan mo sa may radiator kung maganda pa ang ikot or gumagana pa pag tumaas yung temperature.
ricepower is offline   Reply With Quote
Old 05-31-2012, 12:58 PM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
baka may momo....katakot hi hi hi
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-01-2012, 08:43 AM   #6
BoyMalambing
So far ok na sya after ko mahigpitan yung battery terminals ko. Siguro dahil maluwag sya pag dumaan sa mga rough road nakakalog nagloloose contact. Na try ko ibiyahe kahapon at 12nn papuntang batha ok naman todo AC. Di namna nangyri uli
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
