Old 05-31-2012, 04:32 PM   #1
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
Lightbulb any other toyotas with higher amp alternators that bolt up to the yaris
looking for a stock toyota denzo 120 amp alternator that is plug and play for the yaris
pennyracer is offline   Reply With Quote
Old 05-31-2012, 05:03 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
As soon as you find it...let us know. I'll be hooking one up.
― Thomas Paine
Old 05-31-2012, 06:21 PM   #3
My 2011's Tacoma's 130A alternator would connect up, but might require some minor bracket fabrication to mount.
The 4 pin connector and its pinout are identical, but the frame is larger.
The part number is: 27060-0P020
Old 05-31-2012, 09:01 PM   #4
pennyracer
boydstir
pennyracer's Avatar
i was looking at autozone with the tacoma alternator pictures they are showing a oval 3 wire plug maybe the picture is wrong looks like it would bolt up i will look into that one more thanks again ctscott
Old 05-31-2012, 09:21 PM   #5
This is what it actually looks like. Many parts sites use generic images. The pulley is also for a wider belt.
Old 05-31-2012, 11:38 PM   #6
09sedan
Drives: 2009 yaris sedan
this is the only aftermarket solution i have found so far
http://www.qualitypowerauto.com/catalog.php?item=470
or
https://www.dcpowerinc.com/fit/2009~...03-180-hp.html
09sedan is offline   Reply With Quote
Old 06-01-2012, 11:05 AM   #7
pennyracer
boydstir
pennyracer's Avatar
i will go to the local parts house and buy that tacoma alternator and see if it will bolt up if not just take it back and keep looking till i find a match . the pulleys can be changed no problem most of the time ctscott is your tacoma a 4 or 6 cylinder
Old 06-01-2012, 11:10 AM   #8
6 cyl with the towing package and heavy duty built in inverter (120 VAC outlet built into the bed), which is why it has the 130A, instead of the 90A or 100A, which some of the Tacomas have.
Old 06-01-2012, 11:53 AM   #9
pennyracer
boydstir
pennyracer's Avatar
i just noticed that in the options on 130amp alternator listing i hope to try this later today
Old 06-01-2012, 06:51 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
So it's viable to replace the Tacoma pulley with a Yaris pulley and fab some brackets up to fit the Yaris mounting?
I'm looking at costs here...
$90 for a used Tacoma alty
$16-$20 for a Yaris alty pulley
Several hours of bracket fab. This is POSSIBLY something that Garm might want to look into for a "kit". A higher output Toyota/Denso alternator kit for the Yaris.
Hmmm....
I just dropped Garm a message. We should get his thoughts on this. I know I would rather use an OEM alternator for the sake of longevity and peace of mind. I didn't have a good experience with DC Power.
― Thomas Paine
Old 06-01-2012, 07:29 PM   #11
Sounds a little involved if pulleys have to be swapped also. Is there a market for this? I'm a volume-knob audio-noob.
Old 06-01-2012, 08:55 PM   #12
pennyracer
boydstir
pennyracer's Avatar
soon as i do the test fit i will post the details i plan on using my pulley of my denzo alternator if all goes smooth
Old 06-02-2012, 10:06 AM   #13
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I'd be all over a set of brackets, swapping pullies is pretty easy(most of the time!)...
I still have that 1 off NST alternator overdrive pulley, i yanked it because my alternate felt like it was getting way too hot.
-Type 07 FFL-
My odometer 03/11
Old 06-03-2012, 04:34 PM   #14
pennyracer
boydstir
pennyracer's Avatar
okay pulled my alternator and went to the auto parts house and damn it they dont have it on hand so i had them order one so in a few days i will try this alternator swap again
Old 06-13-2012, 01:48 AM   #15
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
this is exciting....I was also looking at my buddies alternator on his Tacoma and it looks like a good fit electrically,and if the pully can fit the mount would be easy enough.
Old 07-21-2012, 10:43 AM   #16
harda toenail
Drives: Want a yaris
Any updates on this?
harda toenail is offline   Reply With Quote
Old 08-17-2013, 12:52 PM   #17
pennyracer
boydstir
pennyracer's Avatar
i will try to pull my alternator and take it to the parts house and match it to the 2011 tacoma ctscott gave me specs on long over do for this change
Old 08-24-2013, 04:46 PM   #18
pennyracer
boydstir
pennyracer's Avatar
None of the parts houses here have the 130amp Tacoma alt to check fitment
Toyota's Yaris TRD VitzBoy General Yaris / Vitz Discussion 10 07-24-2006 08:10 PM
