Old 05-31-2012, 07:44 PM   #1
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Wheelspacers XP9 (2009)
Hey guys!
I have a question about wheelspacers for my yaris.
I want to give my yaris a more wider stance.
My yaris has been lowered with 25mm Eibach suspension and I just want to show it more by putting my wheels a bit to the outside.
Is it possible to fit 20mm/25mm on the rear axle and about 10mm/15mm on the front axle?
These are my wheel specs: 195/50/R16
What are the negative effects on wheelspacers (especially in the front, i heard)?
Thanks!
G-Ammo is offline   Reply With Quote
Old 05-31-2012, 09:50 PM   #2
There are no negative effects.
In the rear, we recommend hub spacers, I have them on the shelf in 10mm and 13mm width
For the front, Ichiba and H&R are good brands and include the longer lug studs you'll need for anything over 5mm. 10mm, 15mm, 20mm and so on are available.
Old 06-01-2012, 08:38 AM   #3
G-Ammo
G-Ammo's Avatar
What's the difference between hub spacers and wheelspacers then? (sorry i'm a newbie on this :D)
Old 06-01-2012, 09:09 AM   #4
G-Ammo
G-Ammo's Avatar
BTW these I want for the rear:
http://www.spoorverbreder-shop.nl/ma...5-p-66060.html
And these on the front:
http://www.spoorverbreder-shop.nl/ma...5-p-66027.html
It's dutch :D but I think the measures are international ;)
Only thing I have to figure out is about those bolts... if they are radius or conical (or something). But I'll ask my dealer.
Old 06-01-2012, 09:40 AM   #5
You gave tire specs, not wheel specs. If you post your wheel size, width and offset, I can tell you what spacers are going to work on your car. Probably not 20mm or 25mm.
Hub spacers go behind the hub, so you don't have to change your lug studs or nuts at all. They also add zero strain to the bearings. Ours are designed specifically to fit the Toyota Yaris:
http://shop.microimageonline.com/Rea...cers-PGHS1.htm
Old 06-01-2012, 01:31 PM   #6
G-Ammo
G-Ammo's Avatar
I see.
Is it possible to install the spacers myself? Or is professional installation recommended?
Can they also be mounted on the front?
Old 06-01-2012, 03:02 PM   #7
Hub spacers are rear only. If you can get the hubs off, it's a very easy job. The Yaris hubs have threaded holes you can use with a long bolt to force them off when necessary. Convenient!
Old 06-01-2012, 03:05 PM   #8
G-Ammo
G-Ammo's Avatar
Thank you very much for your answers!
Old 06-13-2012, 12:20 AM   #9
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
cali yaris.. since OP is planning on putting the spacers on his stock wheels.. which spacers would you recommend for his setup? 10mm or 13mm?
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 06-13-2012, 01:37 AM   #10
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
^ it would be up to the OP.. the 13mm look more aggressive (thats what im running) and the 10mm would just make it look more flush with the front wheels. im on 15 x 6.5 and i love the 13mm's, i installed them a couple weeks ago and i havent experienced any rubbing.
OP, the install is super easy. the hard part is getting that drum off because of all the brake dust and road grime, but its not like you need a mechanic to do it.
just a lift, some jack stands and wrenches... but i did what garm said by using a bolt in the threaded holes, it helped out a lot.
looks fun right :)
lol okay
Old 06-13-2012, 02:37 AM   #11
barebonedvitz
looks fun right :)
thanks! this was the answer that i was looking for
One Love 2009 mrstunerbox Southeast 6 09-24-2009 07:00 AM
2010 or 2009? Newfie Sunrize Canada 3 09-12-2009 03:07 PM
2009 info needed for the 5 spd uncleyaris General Yaris / Vitz Discussion 6 07-29-2009 02:09 AM
May 2009 Yaris sales: Down 26.9% Thirty-Nine General Yaris / Vitz Discussion 10 06-04-2009 09:33 PM
