Old 06-02-2012, 01:19 PM   #1
farrukhahmed
Drives: yaris 05
severe jerking on up-shifts
i'm having a serious problem with my yaris '05 1ltr. the transmission jerks like crazy on every up-shifts, so much so that it has broken the wheel spindle twice and the gear mount once...
Also, if I'm at a stop light and put the car in neutral, the same jerk comes even when shifting to D. The only time there's no jerk is on the first shift to D after a fresh start.
as a temporary resolve i've taken off the main grip on the tranny that goes to the ECU. in this way the transmission stays in the 3rd gear even when i start from halt, so you can imagine how slow the pick-up is....i can't climb a simple parking incline and if i switch on the AC while on stop, the car doesn't move at all.
i've had the transmission checked and they said its fine so it has to be something electronic.
i can understand the ECU lingo a bit so it would really help if i can get some relevant opinion from the experts here.
farrukhahmed is offline   Reply With Quote
Old 06-04-2012, 10:09 AM   #2
Em_
Drives: 2007 Yaris
did you check your fluid? maybe try putting in some new fresh a/t fluid
Em_ is offline   Reply With Quote
Old 06-09-2012, 06:48 AM   #3
farrukhahmed
Drives: yaris 05
Done that. I'm suspecting its an electronics issue since I have the wiring replaced. Any lead on wiring related solutions?
