View Poll Results: what to do with this problem?
go to a dealer 7 70.00%
diy 3 30.00%
Voters: 10. You may not vote on this poll
Old 02-24-2007, 12:22 PM   #1
homerj
Safety Engineer
Drives: 09 Fit Sport, 07 Yaris Sedan
my problem + search review ... creaky squeaky dash
my problem is that the glass/plastic cover in front of the guages on my '07 sedan creaks. when i apply pressure to it with my finger it stops. this means that it is somewhat loose. any suggestions to fixing this? i would like to avoid the dealer and i would like to avoid a ghetto/quick and dirty fix...
now, i did a search. here are other people's problems with in-car noises:
rattles while driving around the dash in front of the steering wheel
http://www.yarisworld.com/forums/sho...ighlight=creak
driving on the freeway or just on the street and hit some little bumps, the glove compartment begins to make some clankity sound
http://www.yarisworld.com/forums/sho...ghlight=rattle
weird rattle coming from the engine when it was on idle
had them take a look at the rattle that was coming from the center of the dash ... They removed the speedometer, and placed foam behind that area
start the car after it's been parked for awhile, it would make a high pitched squeal after I turn the key
The glove box was rattling - sounding like it was coming from the a-pillar.
heard a noise in the air conditioner system
http://www.yarisworld.com/forums/showthread.php?t=185
rear speaker plastic panels IS NOW makin the rattling noises
http://www.yarisworld.com/forums/sho...ighlight=noise
devinlamothe ( http://www.yarisworld.com/forums/sho...ghlight=rattle ) had a similar problem, but the people that replied to this person's post said go to the dealer... i think going to the dealer is overkill for this small problem.
homerj is offline   Reply With Quote
Old 02-24-2007, 07:28 PM   #2
RogueYaris
Drives: 2015 Abs Red
Just because you think it's a minor problem doesn't mean it actually is. I would take it to the dealer to start a record of maintenance on the situation. It might seem like a waste of time but it could be the difference of being shit outta luck when more problems arise and being protected with your records.
RogueYaris is offline   Reply With Quote
Old 02-25-2007, 04:05 AM   #3
homerj
Safety Engineer
yeah, i'll be shit outa luck when the dash falls on my lap...
