Old 06-20-2012, 01:56 PM   #1
satdan
Drives: yaris
Help on My A/c
My yaris 2006 compressor was failed and I replace it with after market compressor. After replacement same day it works fine, after that If i start in the morning it took 6-8 Minutes to start the compressor after switching on the A/c and green light is coming.
Why the delay is coming?Is refrigerant pressure low/high? Please advise me.
Thanks in advance
satdan is offline   Reply With Quote
Old 06-20-2012, 01:58 PM   #2
Did you have a mechanic evacuate and charge the A/C system after replacing the compressor?
Old 06-20-2012, 02:29 PM   #3
satdan
Drives: yaris
Yes, He checked and said may be issue with control board. Once the A/c starts to work, it works fine for hours no issue.
Only initial delay after stopping for 5 to 6 hours. Since in the morning i have to drive only for 10 Minutes, in hot summer here it is very difficult to drive inside the car without A/C.
Please explain me why these starting delay,
Here(UAE-Fujairah) the mechanic is not good, & I yet to find the good one.
Old 06-20-2012, 02:43 PM   #4
The starting issue would be due to pressure (too low or too high). It could be that the mechanic did not charge it to the factory specification or it could be that the pressure sensor is bad.
Old 06-20-2012, 02:51 PM   #5
satdan
Drives: yaris
Thanks for your reply, low pressure was around 60psi @ 40 Deg ,I will check the both by tomorrow & post here.
Old 06-20-2012, 02:55 PM   #6
That should be OK as it should be 57 to 85 PSI with the compressor not running.
Old 06-20-2012, 02:57 PM   #7
satdan
Drives: yaris
Cooling is not the issue only delay in start of compressor, Mainly after long gap keeping vehicle OFF.
If I run the vehicle in middle after 1 Hr, No issue, compressor starts to work immediately!!
Old 06-20-2012, 03:01 PM   #8
That makes me think the pressure is low and the heat of the engine running increases the pressure enough to let it decide to start.
Old 07-04-2012, 12:01 PM   #9
satdan
Drives: yaris
The mechanic checked the pressure said Ok, but the clutch is not working properly and asking me to change the compressor new. Is it correct?
Old 07-04-2012, 05:12 PM   #10
That's an expensive repair, so I would ask him to prove what the clutch issue is.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C compressor yaryar83 General Yaris / Vitz Discussion 3 06-03-2012 09:47 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
