Old 06-20-2012, 03:28 PM   #1
nmjams
Drives: toyota Yaris vvti
just bought a Yaris, keyless entry question
I bought my Yaris last night off an old deer, she gave a single key and a bunch of 3 keys, one of which had keyless entry buttons on it.
Today i checked all the keys, 2 of them including the 1 with the keyless entry buttons did not fit the car. That leaves me with 2 keys.
My question is should my Yaris have keyless entry, i've searched the net but found nothing.
toyota Yaris vvti colour collection 998cc (02/03?)
nmjams is offline   Reply With Quote
Old 06-20-2012, 03:49 PM   #2
The keyless entry receiver for your RHD 02/03 is located under the dash above the steering column. Connector W4 in the diagram below is where it would be connected to. You may be able to shine a flashlight (torch) up under the dash to see if it is present. Otherwise, if you want to PM me the VIN for you car I can run it through the EPC to see if it indicates that the car was built with it.
Old 06-25-2012, 02:00 PM   #3
nmjams
Thanks CTScott, after a conversation with my local Toyota dealer i've discovered that my car definitely has Remote central locking, but, and it is a big but,it will cost £200 or more to get a new one sorted as i don't have the original fob!
Can i get a new one for less somehow?
I really want remote central locking but i dont know if its worth paying that much for it
Old 06-25-2012, 02:55 PM   #4
Is the dealer quoting you £200 for just a fob?
Old 06-25-2012, 02:59 PM   #5
nmjams
No mate, that's for everything. including VAT. It could be more.
Old 06-25-2012, 03:17 PM   #6
In that case, I would go with an aftermarket keyless entry system, which over here could be purchased for around $50 USD. With existing power locks, installation is fairly simple with only about 8 wires needed to be tapped to existing wires.
Old 12-29-2014, 09:40 AM   #7
smah
Drives: Toyota yaris 99 reg
Hi CTscott
smah is offline   Reply With Quote
Old 12-29-2014, 09:42 AM   #8
smah
I have got a toyota yaris 99 reg vvti. I have central LOCKING factory fitted and I bought the aftermarket universal keyless entry system as you suggested in the post. Can you please please please explain how to install. Much appreciated
Old 01-11-2015, 02:59 AM   #9
richie-318
Drives: yaris 1.0gs
Hi I have one of the cheap aftermarket key less entry systems for my 2000 GS. Can anyone help me with regards to what wires and where. Know the drivers side kick panel comes off but what colours do I Splice into.
How the hell do I work out which wires from the key system actually wire into the yaris? The wiring diagram that came with it is pants.
Would I just be better getting a wireless receiver and cable from a breakers and just wireing that up to the door control box and then getting a key to program?
Does the other end of connector from the wireless box just connect somewhere elseunder the dash or is it wired in.
AHHHHHHHH All I want is remote central locking on my reliable 2000 yaris.
thanks in advance
richie-318 is offline   Reply With Quote
Old 01-11-2015, 11:02 AM   #10
I don't have access to a European MK1 Yaris to be able to document the installation of a remote starter or keyless entry system on one. There are also wiring differences between the pre and post facelift ones as well as for the different engine configurations.
KEYLESS ENTRY kit for Yaris Y(GCC version) --- 56k warning ricepower Middle East 9 09-25-2014 02:23 PM
Help! Keyless entry on a 2007 liftback?! sd_007 DIY / Maintenance / Service 4 05-28-2009 04:01 PM
