Old 06-23-2012, 12:20 PM   #1
JonathanHB2011
Drives: Yaris 2011 1.3L
air intake
I am getting crazy where to find air intake for yaris 2011 with 1.3L engine... Need help from you guys...
JonathanHB2011 is offline   Reply With Quote
Old 06-23-2012, 01:10 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Can you post a pic of your engine without the stock air box on it? Also a closeup of your mass airflow sensor to see if it's the same one as the 1.5. While the air box is off, measure the outside diameter of your throttle body. You might be able to use a 1.5 short ram intake if your sensor matches.
Old 06-23-2012, 03:07 PM   #3
I'm pretty sure it's all compatible. I'll check through my emails.
Old 06-24-2012, 01:36 AM   #4
syntax
syntax's Avatar
@ jonathan.. it's all compatible, get it from garm. MI
Old 06-24-2012, 10:44 AM   #5
JonathanHB2011
hi syntsx. what is garm?
Old 06-24-2012, 11:23 AM   #6
^ garm is post #3, cali yaris owner of microimageonline.com
Old 06-24-2012, 11:25 AM   #7
tooter
play every day
tooter's Avatar
Originally Posted by JonathanHB2011 View Post
what is garm?
We haven't quite figured that out yet.
Old 06-24-2012, 12:19 PM   #8
I am Garm.
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
