Old 07-01-2012, 06:50 PM   #1
spin_king
Drives: 03' 1.5 vitz rs
Question driveterrain (clutch / pressure plate)
I kknow making power from a manual car is in de pressure plate & type of clutch you use.
My question is, can I replacee my old stock clutch & use a performance clutch & leave the stock pressure plate? Would the stock pressure plate clamp load would be enough for a act 4/6 puck or full surface clutch
This is for the '03 1.5 yaris/vÍtz RS
spin_king is offline   Reply With Quote
Old 07-01-2012, 08:24 PM   #2
if youre going to the trouble of replacing the disc, you might as well do the pressure plate
that said, an oem clutch will absorb tons of abuse as long as you're not turbo'd or supercharged
Old 07-01-2012, 10:27 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
make sure you resurface your stock PP if you keep it. Watch out on those 4/6 puck deals...they are serious when it comes to leg fatigue.
act, clutch, drive, pressureplate
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Urgent advise Needed MT Clutch & Bearing Spec. victorddr DIY / Maintenance / Service 4 04-23-2011 10:27 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
