Old 07-04-2012, 01:23 PM   #1
2o6
Drives: 2007 Liftback
Accessory belt replacement intervals?
I just looked at my accessory belt today, it looks terrible. Frayed, very discolored, doesn't look good.
I was driving and I heard a notable squeal, alternator light came on for a second, then it went right off. I know it's not power steering; ours is electric. Not sure if a bad alternator would cause the belt to slip, or if the belt was overtightened at some point and the hot weather caused it to stretch and now it's bad.
How often is this belt supposed to be changed?
2o6 is offline   Reply With Quote
Old 07-04-2012, 04:08 PM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Obviously its time to change that belt no matter what the interval.
I keep a log book in my glove box and write down when and at what mileage i change anything on the car so i know exactly when the last time i changed anything and i can cross reference with the owners manual that i am within parameters.
Accessory belts for me get changed every 30K which usually equates to every 2 years.
If you dont know when the Accessory belts were changed last what other maintenance items are past due for replacement,PCV valve,air filter,plugs+wires,tranny oil,radiator flush, brake fluid, brakes,tires,.
Probably 50K interval would be a reasonable time to replace the new belt.
Have Yaris will travel..
Old 07-04-2012, 05:36 PM   #3
RedRide
RedRide's Avatar
I agree..... if it looks bad just change it. Ther rule of thumb for when to change it (on any vehicle) is "when it needs to be changed".
Fortunately, the belt on the Yaris is relatively easy to change as compared to a lot of cars and for the little expense involved, it's better safe than sorry.
Old 07-04-2012, 06:18 PM   #4
jalancast
Drives: Yaris 4Door
60k-90k is a pretty typical interval, only the old eyeball is your best bet. Sounds like it's time for a new one...
jalancast is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Drive Belt Replacement naowill DIY / Maintenance / Service 2 07-02-2012 11:58 AM
service life of accessory drive belt? stevebo DIY / Maintenance / Service 5 05-10-2010 01:29 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
