Old 07-04-2012, 07:18 PM   #1
Lux
Lux's Avatar
Drives: NCP91
*Tech Talk* Low-viscosity Oil in 1NZ-FE
Hi Yaris World
I have a few technical questions for the gear heads around here. This is intended for highly experienced service technicians and engine builders.
I am experimenting with the use of low-viscosity (0W-20, 5W-20) motor oils for my 1NZ-FE engine for further reduction of parasitic loss (short of knife-edging the crankshaft). I want to ask for some information regarding the mechanical limitations of the NZ engine's lubricating system. My main concerns are with the oil pump, journal and bearing tolerances, valvetrain, VVT-i phasing, and changes in oil pressure.
I know that, by design, the engine is intended for the use of 5W-30. What I'd like to know is whether the journal/bearing clearances will tolerate thinner oil under all conditions... I'm talking about cold start (dry bearings) to extreme-duty race loads. Chemical thermostability is a non-issue as I will use full synthetic oil.
Will the cam phaser be affected by a low-viscosity oil? Has anyone noticed the engine knocking on a cold start (zero oil pressure) due to inadequate viscosity? Any further insight into using 20-weight motor oil on these engines?
This isn't isn't a typical drain & fill question, I'm interested in the science behind viscosity versus the NZ sump system.
Thanks!
Old 07-04-2012, 08:27 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Toyota mandated a few years ago that you could change to 20 weight without an issue. I have used 20 weight for 3 years now in both Northern Maine subzero weather and also in Alabama's hot temps. I never encountered issues in regards to knocking or otherwise. This is with Mobil1 and then AMSOIL.
Old 07-04-2012, 11:24 PM   #3
Hershey
Here's an U.O.A. for 5w-20 from the '08 sedan . Column 1 is Shell 5w-20 syn , 2 is Shell 5w-30 syn and 3 is Pennzoil conventional 5w-30 . All are SN/GF-5 . Not an expert , but the numbers look good . Slight increase with TIN , up 1 . See here for TIN and other metals , etc. , http://www.bobistheoilguy.com/engine-oil-analysis/ . Just drained second fill of the Shell synthetic 5w-20 and went to Shell 5w-30 syn.. There's a Toyota Genuine Motor Oil viscosity chart for Canada and it's the real deal . Got confirmation . Here it is , http://pdfcast.org/pdf/toyota-oil-recommendation .
Old 07-05-2012, 08:04 PM   #4
Lux
Lux's Avatar
Drives: NCP91
That Toyota oil viscosity chart is a pleasant surprise to me. I know the NZ engine is an ageing design, so I didn't suspect that they'd approve 20-weight oil so readily. I reckon if Toyota says it's OK, then I will go ahead with it.
What is your experience with using synthetic gear oil in the gearbox? Currently, I'm not experiencing any shifting issues, but I just thought the action should be smoother than my other cars, even at operating temperatures. I've used MT-90 heavy duty shockproof gear oil in my other car with good results. What do you folks say?
Old 07-05-2012, 10:54 PM   #5
fnkngrv
fnkngrv's Avatar
^ I noticed a big difference in shifting into reverse as many others have by switching to synthetic. I have also noticed better shifting through the gears quickly at high quantity intervals (IE, shifting many times in racing and the city) so in retrospect I have experienced what AMSOIL has stated in regards to gear oil temps running cooler.
Old 07-06-2012, 11:34 AM   #6
Hershey
+1 . The Amsoil MTG is a GL-4 . Here it is , http://www.amsoil.com/storefront/mtg.aspx . It's $14.80 a quart . Went up some .
Old 07-06-2012, 11:59 AM   #7
fnkngrv
fnkngrv's Avatar
I actually am using the severe gear oil:
http://www.amsoil.com/storefront/svg.aspx
The price of course is less if you become a preferred customer and the better pricing is of course on all of their products.
http://www.ttr-online.com/synthetics...tomer-program/
Preferred customer pricing is $9.50/qt for the standard long life and $11.55/qt for the severe.
Old 07-06-2012, 12:07 PM   #8
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
I use a 0w-20 Euro blend oil (I think). I don't recall what brand, but I have a couple bottles in the car, I'll verify tonight. I live on Lake Michigan in WI, and run it year round. Zero problems to date for the 2 years I've used it. Just switched to the Amsoil GL-4 synthetic transmission oil, and noticed a huge difference. It's worth purchasing the 6 month "preferred customer" deal and getting the discount, it'll pay for itself quickly, and you can help friends/family out with the costs you can get too. Hell, charge them retail and make a couple bucks a quart!
Old 07-07-2012, 05:46 PM   #9
Lux
Lux's Avatar
Drives: NCP91
Thanks guys for the insight! I've talked to the parts supplier and ordered an entire case of 1-US gallon jugs of motor oil and 2 bottles of gear oil. It'll be some time before it's shipped to me. Thanks again.
P.S.: I've opted for the regular AMSOIL gear oil, being that the severe duty (a.k.a heavy shockproof in other brands) will be more viscous than I need. The 1NZ doesn't produce enough torque and gear load to make use of it anyway, haha
Old 07-07-2012, 10:52 PM   #10
fnkngrv
fnkngrv's Avatar
This is true if you are running it stock
DRL: Low beam or -lamps - or not? Ot_tO General Yaris / Vitz Discussion 10 07-27-2012 07:11 AM
Canada Toyota genuine motor oil viscosity application chart : 0w-20 approved for ... Hershey DIY / Maintenance / Service 7 06-23-2012 08:35 AM
My Oil Analysis 2007 hb 5 speed 123,994 miles mark293 General Yaris / Vitz Discussion 12 02-25-2012 10:19 PM
Dealership filled engine with too much oil... posaunemeister DIY / Maintenance / Service 17 10-18-2009 11:21 PM
