Old 02-26-2007, 10:41 PM   #1
majorposer
Drives: purchasing
basic suspension upgrade
i don't want coil-overs, and the only struts i've found are TRD's. i know koni doesn't make anything yet, BUT is there more dampers out there that i don't know about?
also, since we don't have much of an aftermarket, does anyone know what car we can use stuff off of? echo? corolla?
-Lucas
majorposer is offline   Reply With Quote
Old 02-27-2007, 12:12 AM   #2
i would like to know about the shocks too.
Old 02-27-2007, 01:15 AM   #3
oscarying
Drives: SLOOWZ
i will recommend the TRD since i m using it and it feels good,comfortable
and its way better than pedders(australian brand) also,its not expensive
oscarying is offline   Reply With Quote
Old 03-01-2007, 01:34 PM   #4
BulletProofAuto
Drives: 00 itr
why don't you want coilovers?
BulletProofAuto is offline   Reply With Quote
Old 03-01-2007, 02:38 PM   #5
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Cusco Compact-S coilovers are a better option than springs....
Old 03-01-2007, 07:17 PM   #6
majorposer
Drives: purchasing
well, i just need a decent suspnesion upgrade. i don't need the coilovers because i'm not going to be corner-weighting them, therefore making them just as useful as a decent lbs-spring and strut. i don't want a crazy drop because i don't want to put my control arms at too much of a bad angle. see, in stock form, the controls are completely horizontal, perfect for the best suspension geometery, but i need to lower the center of gravity. so a compromise needs to be made, lowered a little bit, with a little stiffer dampening. and sometimes faults can be made with too stiff of dampening. this is bad for two reasons. one, if it's too stiff, your wheels won't always be touching the ground over uneven surface, taking away much needed traction. and two, balance is everything. i don't want too much spring, or too much dampening, or too much sway bar.
the coils offer a stiff setup at a high price. the difference between lap times around a even, flat surface will be so little, that the extra money i saved in buying a spring and strut replacement can be used to pay for a couple driving schools to lower my times even more at a autocross, or money for tires.
Old 03-01-2007, 07:50 PM   #7
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
for those that don't know the trd srtuts are from tokico....
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
got the trd suspension installed... tekmoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-01-2007 08:22 PM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 02:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
