Old 07-18-2012, 09:39 PM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Any info on complicated service?
I can do oil change/ fliter etc.
Guyz,u have info on wheel bearings, brake pad replacements, transmission and brake oil change plus the cv axle and joints.
Anyone attempted these?
Old 07-18-2012, 10:50 PM   #2
Lux
Lux's Avatar
Drives: NCP91
Yes, I've done them all.
No, they are not something you should do at home, except brake pads. By the way, rotors must always be changed with pads; I've seen rotors shatter like glass ornaments because the owner thought he could save money by doing just a pad slap.
Rear wheel bearings are detatchable hub assemblies that require a slide hammer to pull out. Front wheel bearings are press-in only, unless you buy a complete steering knuckle with bearing and hub already pressed in ($600+).
CV axle boots are not worth your time. Take it to a professional. Complete axles are doable if you have the 30 mm 12-point impact socket and impact wrench. You'll also need to detach the outer tie rod from the knuckle. You will lose transmission fluid in the process.
Gearboxes are drain & fill. Automatic transmission uses lifetime filter.
Old 07-19-2012, 07:48 AM   #3
junorico24
junorico24's Avatar
Thanks, mate.
It's not for the faint of heart. I just need some info Preferably a tutorial of sort.Not actually going to give it a go.Be good to get an idea where the bolts and what steps to take etc. Can you do a transmission fluid change to synthetic at home?
I hate cable service providers. Altitude Off-topic / Other Cars / Everything else Discussions 27 09-12-2010 09:09 AM
60K Service by Dealer or Independent Mechanic? tomato General Yaris / Vitz Discussion 33 01-19-2010 06:42 PM
Why does 15000 service cost so much more than 5000 and 10000 mile service? monyaris DIY / Maintenance / Service 7 06-25-2009 07:12 PM
Funny Business at the Toyota Service Centre *MAD DOG* DIY / Maintenance / Service 10 01-10-2009 12:47 AM
Metro Atlanta Dealer Service Experiences redyaris Southeast 2 03-21-2007 03:59 PM
