Old 07-19-2012, 12:12 PM   #1
otterhere
Drives: 2008 Yaris 3-door Meteorite
Those of you who have "tweaked":
With lowering springs and/or removing the back seat for increased fuel efficiency, have the results been worth it? I realize most of you do this stuff yourself, but I would be paying a shop (no can do, no handy boyfriend).
Thx!
otterhere is offline   Reply With Quote
Old 07-19-2012, 12:45 PM   #2
anomoly40
Depot Damager
Drives: '08 Liftback
Buy a set of sockets at your local Walmart. The backseat is easy. Just make sure you have the same Torx socket in the diy. Springs require special tools and attention.
http://www.yarisworld.com/forums/showthread.php?t=306
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 07-19-2012, 04:31 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Removing the rear seat is a 5 minute affair. I didn't do it so much for fuel efficiency but for increased braking power and acceleration, as well as to reduce rubbing in the rear (I am indeed lowered with NF210 springs). In my case it was 100% worth it.
Old 07-19-2012, 04:49 PM   #4
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
the only specialty tool needed for the springs is a spring compressor. you can "borrow" one from autozone, advance auto, or oreileys using the "loan-a-tool" program. an impact gun helps but is not absolutely needed.
honestly, anything that costs money to save gas usually doesn't pay for itself. there are exceptions. a good fuel economy gauge (scangauge, ultragauge, ecometer) I think is a good investment.
If I lived closer, hell I would change your springs. it was kind of fun. I learned a lot.
you may want to take some smaller steps first with fuel economy like airing up tires and working on your driving style.
it is a long read but you may pick up a tip or two from it.
http://www.gassavers.org/article.php...ps-to-save-gas
Old 07-20-2012, 02:36 PM   #5
otterhere
Thanks, Beef; never thought of removing the seat before, but I always keep it down for carrying bike, kayak, or groceries and wouldn't mind a "two-seater"... I DO try to keep my 14" tires at 40 psi; otherwise, my mpg is tooooo depressing!
Old 07-20-2012, 03:57 PM   #6
BEEF
BEEF's Avatar
my only thing about taking out the back seat is if you ever do need to take someone along (I'm a parent so my daughter's car seat has a permanent place back there) and the looks factor. the ones I have seen without the seat look a little rough though I figure you could put something in its place like a blanket or small carpet just to cover the ugly.
you have 14" tires? mine are 15s.. wonder what the difference is? (I know, an inch)
Old 07-20-2012, 04:37 PM   #7
Klink10
Klink10's Avatar
Took mine out and never looked back. Gas mileage has remained steady at around 35-40 if I don't stand on it. I am lowered but with backseat removal it kinda gives it a mild raked look which I like.
Old 07-20-2012, 05:42 PM   #8
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have my entire rear gutted and I love the result. It brakes better and you can feel a nice difference on hard pulls. It really is not that hard I am sure you can do it yourself. Just buy a basic socket set at your local hardware store as a shop doing this free mod is going to be $$$.
Springs are going to be harder so you may want to get professional help.
If you need help with any diy pm me i will do my best to assist.
Removing the rear seat is a 5 minute affair. I didn't do it so much for fuel efficiency but for increased braking power and acceleration, as well as to reduce rubbing in the rear.
exactly what i did and why
