Old 07-22-2012, 12:08 AM   #1
pb10
Drives: 2007 Yaris
Very Strange Starting Problem
Hello,
My first time posting here so thanks in advance for any help.
I have a 2007 4-door Yaris. Every few times I try to start the car, it will not even turn over. It's just absolutely dead, as if the battery is dead. This has been happening for a few weeks now and I cannot seem to find any trends relating to when it happens or what causes it.
I have found a way to get the car to start though. If I pop the hood and then lift or touch the red cap that covers the positive terminal on the battery, the horn will blast one time and then the car's electrical system will kick in again, allowing me to start the car without any problems. Almost as if I've reset the system somehow.
I really have no idea why the car does this or why when I touch the terminal cap, the horn goes off and the electrical comes back on. If anyone has any ideas, I would really appreciate it.
Thanks!
pb10 is offline   Reply With Quote
Old 07-22-2012, 04:36 AM   #2
willygoodness
Drives: 09 yaris hb
loose nut/bolt on the terminal maybe..?
willygoodness is offline   Reply With Quote
Old 07-22-2012, 12:12 PM   #3
pb10
Drives: 2007 Yaris
Thanks for the input. One of the terminal bolts was slightly loose. I tightened it so we will see if the problem comes back.
Thanks again!
Old 07-22-2012, 08:24 PM   #4
harda toenail
Drives: Want a yaris
That was most likely the problem. Any time something works when moved it is a short or loose. Battery terminals sould be good and tight.
harda toenail is offline   Reply With Quote
2002 diesel, problem starting when engine is hot casadelaloma DIY / Maintenance / Service 0 10-18-2010 09:02 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
Problem starting on Hill? FcukThis General Yaris / Vitz Discussion 0 08-09-2010 08:01 PM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Strange problem... can anyone help... adigilani DIY / Maintenance / Service 10 06-01-2010 06:14 PM
