Old 07-23-2012, 08:25 PM   #1
gswell
Drives: yaris 07
Display does not show what gear I am in
the yaris we just bought dosen't display what gear you are in (D, R, 2, 1, etc) it is just blank.
any ideas?
gswell is offline   Reply With Quote
Old 07-23-2012, 08:38 PM   #2
The shift positions go to the ECM as separate inputs and then the position is sent to the cluster as a CAN Bus message, so the two things I would check are:
1. 10A GAUGE fuse in the fuse panel under the bottom of the dash.
2. Make sure the 9 pin connector on the automatic transmission is plugged in.
Old 07-23-2012, 09:31 PM   #3
gswell
Drives: yaris 07
Thanks so much Scott! I'll report back
Old 07-23-2012, 10:54 PM   #4
I'm pretty sure the earlier Gen 2s didn't feed the dash display. My '06 dosen't even though you can see on the cluster where the indicator would show.
Old 07-26-2012, 01:11 PM   #5
gswell
Drives: yaris 07
the fuse looked ok, im guessing this is an earlier model that dosen't display. thanks for the help guys!
Old 01-04-2018, 07:27 PM   #6
Dee
Drives: 09 1.3 auto Yaris 3dr silver
Is there any chance to make it work?
Dee is offline   Reply With Quote
Motion Auto Show 8/21/11 cali yaris California 2 08-20-2011 12:50 PM
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
ROCKLAND SCION'S FALL FESTIVAL 2009 9/13/2009 ROCKLAND TOYOTA NY / NJ/ CT / PA 18 09-15-2009 10:31 PM
ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 ROCKLAND TOYOTA NY / NJ/ CT / PA 198 08-05-2009 01:04 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
