Old 07-24-2012, 12:21 AM   #1
dlrotter
Drives: 07 Yaris
Auto trans randomly shifts into low gear?
My 07 Yaris randomly shifts into low when driving on the highway. The shift indicator will show D but randomly also shows LOW at the same time... Can it be the oil? It looks good and no leaks. Someone said it could be the "Park Neutral Position Switch". Where is it? Any other ideas?
dlrotter is offline   Reply With Quote
Old 07-24-2012, 08:16 AM   #2
I would suspect the switch, particularly if it only shows the wrong gear and doesn't suddenly start screaming at high RPM. The switch is part of the transmission.
Old 07-24-2012, 08:50 AM   #3
dlrotter
Drives: 07 Yaris
Oh yea. It does actually shift into low gear causing engine to scream. More thoughts?
Old 07-24-2012, 10:31 AM   #4
Yikes! The fact that you see the indication of gear change on the cluster says that it is most likely not an internal issue, but rather an external one, perhaps with the linkage to the park/neutral switch assembly (which feeds the gear selector position info to the ECM). It may be as simple as one of the bolts having come loose where the shift cable meets the selector.
Old 07-24-2012, 11:28 AM   #5
dlrotter
Drives: 07 Yaris
Thank you for the feedback and diagram! I'd does seem like it may be a sensor telling it to shift to me. Have any leads as to where to pick up the sensor if it is the prob after I check linkage? Dealer was about $580! O'Reilys a little cheaper...
Old 07-24-2012, 11:47 AM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Just a guess... but isn't there something that senses a loss of manifold vacuum signalling a heavy engine load that downshifts the transmission? Maybe the vacuum line from the manifold to the engine load sensor is leaking. If the sensor lost its vacuum signal, it would drop the transmission into low because it would behave like the gas pedal was pushed to the floor.
(ok CT... now you can tell me how wrong I am again )
Old 07-24-2012, 11:51 AM   #7
^LOL - The fact that the cluster display shows the gear changing, means that it is happening by external, rather than internal influence.
As for finding the selector switch, junkyards would be the place to look. An entire transmission can be had for $350 on eBay.
Old 07-24-2012, 12:00 PM   #8
dlrotter
Drives: 07 Yaris
Ok I'll look at junkyards too. Tooted, I was thinking the same way at first too. But when driving more it randomly changes. I can barely be giving it gas basically just coasting at 55 mph and randomly shift to Low. (I wish the car had a tach for curiosity sake...) T hat motor can scream.
Old 07-24-2012, 10:24 PM   #9
dlrotter
Drives: 07 Yaris
I found my problem! There was water in the connector. Looked like once water got in. There is not a was for it to drain or evaporate. Cleanned it up and so far working ok.
auto, park neutral position, prndl, transmission
Reluctant upshift to 3rd while cold (auto trans) pauljk General Yaris / Vitz Discussion 40 01-22-2011 06:04 AM
Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty YarisSedan California 1 10-31-2008 08:32 PM
Auto 'extra' gear? drecian General Yaris / Vitz Discussion 2 08-25-2007 08:01 AM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
