Old 07-25-2012, 01:00 AM   #1
kropekoi
Drives: vios 1.3J
Post vios engine swap to 2zzge
any links for any documentation that this has already been done?
I checked on the sticky that its already been done on a sedan, however, are there any links or any info about the costs, parts to change, or if the transmission of vios sedan will fit the 2zz engine?
Please enlighten us great ones!
kropekoi is offline   Reply With Quote
Old 07-25-2012, 01:02 AM   #2
kropekoi
Drives: vios 1.3J
Pictures or videos maybe?
Old 07-25-2012, 05:22 AM   #3
It's been done here, and in Puerto Rico, but nobody seems to be able to find any solid information/build logs :(
Old 07-25-2012, 04:13 PM   #4
kropekoi
Drives: vios 1.3J
I believed that you've done it as well, however, I am not sure on what engine you've used.
how much did it cost you? and how's the overall performance?
Old 07-25-2012, 06:28 PM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
^i think he has a 4agze installed?
Old 07-25-2012, 06:47 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup, that is what Thomas is running. In his neck of the woods doing a major swap for here is a drop in the bucket cash wise from what it sounds like.
Old 08-20-2012, 02:23 AM   #7
kropekoi
Drives: vios 1.3J
do sedan and hatch has the same bolt pattern to fit the engine? I mean would it also fit the sedan vios with a 4agze? that is the turbo charged 4age right?
Old 08-20-2012, 02:37 AM   #8
oops didn't see this thread replies..
Yes, I'm running a 4A-GZE converted to turbo, but it was NOT an easy swap, engine bay frame rails are too close together and had to be trimmed. Took 9 months and about US$7,000 to get it done.
*apparently* a 2ZZ is much more straightforward to fit, and I sometimes regret not going that route.
That being said, I love this new engine :D under 3000RPM it behaves more or less like a normal engine, but once the boost kicks in after that, wheeeee... Right now it's running at low boost, with about 200hp at the wheels, but the engine's been tested to run at 300hp with no issues, but I'll need a few other upgrades before I turn up the boost.
Here's a quick walkaround showing the engine in details:
http://youtu.be/sWzhuMHjBtc
and some more details:
http://www.yarisworld.com/forums/showthread.php?t=40838
Old 08-20-2012, 07:18 AM   #9
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
how much power a 2zzge gives into a yaris ? just curious
Interior:ALL red, black roof
Old 08-20-2012, 07:40 AM   #10
stock it's about 180-190 I believe?
Old 08-20-2012, 07:49 AM   #11
packetrace
packetrace's Avatar
Does the stock engine mount fit ?^^
Old 08-20-2012, 11:31 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
http://www.yarisworld.com/forums/sho...t=15242&page=5
You should really spend a few and read this entire sticky.
But to answer you question, no. Only 1 motor will bolt directly up to the usdm yaris with no fab work is the 2zr-fe that would increase power. Same motor thats in the Scion xD. You will need to get the motor mounts from a european yaris that has that same motor I believe. 2zr is about 130hp, so its only a 25hp gain. but its a 1.8L. The worse part I think would be your re-wire dash harnes and ecu harness to get all guages and stuff working properly. or just run standalone
-Derrick-
Old 08-20-2012, 11:40 AM   #13
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
so much work to swap these cars :(
Old 08-20-2012, 11:47 AM   #14
fnkngrv
fnkngrv's Avatar
more and more it will be this way from the manufacturers unless you buy a Dodge Dart..haha. I think those have like 7 trim levels and 4 different engine/tranny combos.
Old 08-20-2012, 07:43 PM   #15
ilikerice
ilikerice's Avatar
is the awd available for the Dart? Was watching a rally and there was a dodge dart in the mix (awd).
-Derrick-
2zz ge, 2zzge, sedan, vios, yaris
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
TC swap? MicroHB Performance Modifications 38 03-26-2009 12:39 AM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
