Old 07-28-2012, 01:12 AM   #1
roneezy360
roneezy360's Avatar
Drives: Toyota Yaris 2007
Replacing Tailight Bulbs
Can anybody list complete instructions as to replacing the brake bulbs in the tailight. My left one went out and when i tried to pull it out on both sides the right one went out as well lol. I tried twisting it but it just wont budge and at this point I just want to ask for help. So yeah lol thanks.
roneezy360 is offline   Reply With Quote
Old 07-28-2012, 08:07 AM   #2
Klink10
Klink10's Avatar
Try pushing it in then twist. It has little tangs which need to dislodge.
Old 07-28-2012, 09:32 AM   #3
don't they just pull strait out?
Old 07-28-2012, 12:34 PM   #4
RedRide
RedRide's Avatar
It should be a #7443 bulb which would pull sraight out.
Old 07-29-2012, 12:50 AM   #5
roneezy360
roneezy360's Avatar
It doesnt pull straight out nor can i twist it. Its literally stuck in.
Old 07-29-2012, 01:00 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
that will happen on one that is as old as yours...it will take some coaxing and you might even need to use pliers. I had to tear my bulbs out of mine when I upgraded to LED a couple years back on my 07.
Old 07-29-2012, 02:03 AM   #7
roneezy360
roneezy360's Avatar
Do you mind caring to explain more detail as to how you took yours out? This whole thing is frustrating me and ive been driving with only my top brake light working and its the end of the month and ive seen too many cops on the street trying to fill their quota. Im lucky not to have gotten a ticket yet and im aiming to get this fixed tomorrow. Any detail as to how you got yours removed would be greatly appreciated.
Old 07-29-2012, 08:24 AM   #8
http://www.yarisworld.com/forums/showthread.php?t=1367
ok according to this thread the bulb should be a 7443, which is a pull out type. (no twisting)
put a rag over the bulb and yank the mother out. That way if it breaks you won't get sliced up and take the rest out with pliers.
Old 07-29-2012, 04:34 PM   #9
roneezy360
roneezy360's Avatar
Wow, thanks for the info and link. I didnt know itll pull right out by removing the 2 nuts. Thanks!
Old 07-30-2012, 04:42 AM   #10
roneezy360
roneezy360's Avatar
Well I finally managed to remove and replace my tailight bulbs. The hard part was twisting the socket off the tailight. Then another obstacle I faced was removing and re-putting the lightbulb into the socket since it took a bit of force. Well, im happy it worked.
replacing tail light bulbs on '08 liftback YannitheYaris DIY / Maintenance / Service 10 01-24-2024 05:44 AM
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 09:07 PM
Any threads on here for replacing license plate bulbs? JerseyJeff84 DIY / Maintenance / Service 3 09-05-2011 01:18 PM
Replacing LICENSE PLATE bulbs... fnkngrv DIY / Maintenance / Service 1 09-01-2010 04:07 PM
Replacing Headlight Bulbs? Tatsh DIY / Maintenance / Service 12 05-13-2010 10:50 AM
