Old 07-28-2012, 05:07 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
exhaust bracket bolt?
Anyone know the part number to the bolt that goes into the side of the header bracket. it is by where the bottom of the header and the mid-pipe meat. Mine worked it's way out driving through Columbia yesterday and now my car sounds like a go cart or a lawn mower until it warms up good. I would assume that the bolt held the mid-pipe in just the right place to close a small gap.
Old 07-28-2012, 05:14 PM   #2
Golddeenoh
Golddeenoh's Avatar
goes between/through parts 1 and 3 in this picture
Old 07-28-2012, 09:29 PM   #3
91672-81025
Old 07-29-2012, 08:38 PM   #4
Golddeenoh
Golddeenoh's Avatar
thanks, found a bolt in the garage that works but i'm sure I will need to replace it for the right one sooner or later.
Old 07-29-2012, 08:46 PM   #5
If you found one that fits you are all set.
Old 07-30-2012, 04:40 PM   #6
Golddeenoh
Golddeenoh's Avatar
well when I was putting in the bracket bolt I realized that one of my shiny new stud nuts had backed off and that the real exhaust leak is from there. so now I get to aggravate Garm and order a new stud kit to replace that one nut. :D of course it is the one that was difficult to get to from the top so I will have to get to it from the bottom and make quadruple sure it is tightened down right next time.
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
