Old 07-30-2012, 02:47 AM   #1
wcruzv
Drives: Yaris 2012
Need Help! Headlights wont turn off.
...ok so today my factory alarm on my new sedan got activated when a friend got out of the car, this car didnt came w/ a remote, i just need to get the car on ACC or ON and it shuts off, but the thing is that after i shut down the alarm the headlights stayed on...i started the car, turned it off, basically did everything and the headlights wont turn off... since im a newbie idk if i need to hit a hidden button or w/e... i even had to disconnect the batt. cause if i didnt i was gonna end up with a dead batt.
i will really appreciate any help on this, thanks in advance!
wcruzv is offline   Reply With Quote
Old 07-30-2012, 08:45 AM   #2
bronsin
bronsin's Avatar
Did the dealer install the alarm or did it really come from the factory? I bet thats where the problem is.
Installing alarms leads to problems like this in my experience.
Old 07-30-2012, 08:59 AM   #3
It sounds like the relay contacts stuck for the headlight output. If that is the case, a slap of the unit will typically release them. If it is the OEM TVIP alarm system, then the module is behind the passenger glove box, against the fender well. If it is not the OEM system, then it is probably tucked under the steering column.
Old 07-30-2012, 02:48 PM   #4
wcruzv
Drives: Yaris 2012
thanks for the advice guys, well i decided to go to the dealer and they told me theyve never seen this happen so they told me to leave the car tmrw so they could see what the problm is, cause i dont want to get my hands on the car and then getting told by those guys that i messed up the warranty since i bought this car 1 week ago...
Dashboard lights turn off when I turn use headlights patate15 DIY / Maintenance / Service 7 07-05-2020 03:05 AM
This mod makes the headlights turn off when the ignition is turned off patm DIY / Maintenance / Service 10 06-25-2012 10:37 PM
2010 yaris Projector headlights yaris2010RS Items for Sale by private party 9 01-09-2012 05:31 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
