Old 07-30-2012, 11:19 AM   #1
bronsin
bronsin's Avatar
Proceedure For Cleaning Battery Terminals
I was reading an article how to clean battery terminals. They say use origional coka cola and a wire brush.
Is this a joke or is it for real?
If it works please explain whether or not its OK to drink it.
Old 07-30-2012, 11:36 AM   #2
A brush is all that is necessary. I like the ones that have a inner brush for the post and an outer brush for the terminal. Coke is very acidic and with therefore get rid of some of the build-up, but why make a sticky mess when mechanical cleaning is sufficient?
Old 07-31-2012, 12:00 AM   #3
narly charley
Drives: 2010 Yaris "L" 5 Speed
Steel wool works great too...
narly charley is offline   Reply With Quote
Old 07-31-2012, 12:09 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I do the wire brush and also the water/baking soda mix after to "cleanse". I have done the Coke thing in the past...like Scott says, it is the messier of the different methods.
Old 08-06-2012, 04:40 PM   #5
charles nelson
Drives: red Liftback
You can get a battery cleaning foam. Bright yellow but turns blue where it contacts any acid. Easy to see and washes off with tap water.
charles nelson is offline   Reply With Quote
Old 08-06-2012, 04:45 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
urine
Old 08-06-2012, 11:17 PM   #7
Lux
Lux's Avatar
Drives: NCP91
-Disconnect battery terminal adaptors
-Soak with baking soda + water solution
-Using a wire brush, scrub the terminals and connectors
-Use a pipe cleaner brush (with metal bristles) to clean inside the connector bores
-Rinse with boiling water
-Reconnect the battery
-Spray lithium grease over the terminals to protect them from the elements. Specialised, coloured battery terminal protector sprays do exist to accomplish the same effect.
Sometimes, old battery terminals can develop a thin, dark grey layer of oxidation that is difficult to clean. It feels like hardened sap. Simply brush more aggressively with baking soda to clean it off.
Off-the-shelf battery cleaners can substitute baking soda solution, but always rinse off with boiling water.
Old 08-06-2012, 11:47 PM   #8
Chuck G
Drives: 2010 Yaris Sedan
urine
Straight from the nozzle?
Old 08-07-2012, 01:05 PM   #9
RedRide
RedRide's Avatar
Exactly as CTScott said.
Old 08-07-2012, 02:33 PM   #10
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
After cleaning I use a copious amount dielectric grease on the terminals and the cables. CRC makes a good spray. Or buy a tube of Permatex stuff.
2007 LB W/Cold Wx Package
DMZ is offline   Reply With Quote
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Installation of a Battery Isolator frostbitten In Car Entertainment + Electronics (audio / video / alarm) 3 10-07-2009 12:11 PM
