Old 07-31-2012, 12:26 PM   #1
08blackyari
slowpoke
Drives: 08 blk LB manu. pwr opt & cld
Hitch installation problem
Hey all,
I bought a Hidden Hitch and would like to install it ... but I can't get the old bolts off!! I'm using a 12mm wrench and cant get the nut to budge. I think it may be too rusted. Any thoughts about what I can do?
-Sam
08blackyari is offline   Reply With Quote
Old 07-31-2012, 12:45 PM   #2
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
PB Blaster, let it soak, and an impact tool.
Old 07-31-2012, 01:53 PM   #3
Hopefully you mean you can't get the "bolt", not "nut" to budge? The nut is welded on, so you are trying to turn the bolt, not the nut. As mentioned above, soaking it with a penetrating oil will probably be necessary to get it out without snapping it.
Old 08-02-2012, 09:23 PM   #4
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
die grinder cut it off and start over the sedan hitch would be ideal for the liftback so you dont see it till receiver is in place
pennyracer is offline   Reply With Quote
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 07:50 AM
Where to buy and install a Hitch?? molinee Cosmetic Modifications (Exterior/Interior) 9 12-29-2011 05:13 PM
Failed Hitch Installation fmicle DIY / Maintenance / Service 7 08-11-2010 03:15 AM
Sedan Ducktail installation problem mr_eraserhead Cosmetic Modifications (Exterior/Interior) 11 10-05-2009 12:39 AM
Problem with GTspec strut bar installation Yawesh Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-20-2009 03:55 AM
