Old 08-02-2012, 07:28 AM   #1
2007ToyotaYaris
Drives: 2007 Toyota Yaris Hatchback
Reverse beep
Hi, I was unloading some things out of the car and I accidentally pulled off the little speaker that hangs down near the ceiling for the reverse beep. The wire isn't broken, just unplugged, but I can't see where it is supposed to plug into. Does anyone have a picture of where to connect it? Or is this not a standard item on the car? Thanks
2007ToyotaYaris is offline   Reply With Quote
Old 08-02-2012, 10:39 AM   #2
That is not a standard thing. Chances are that it is wired to one of the two tail lights, so I would pop off the inside covers to see if you can find the connection point.
Old 08-02-2012, 11:49 AM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
reverse beep speaker?
Old 08-02-2012, 06:10 PM   #4
2007ToyotaYaris
Yeah it makes a beep sound when I am about to back into an object.
Thanks for the info CTScott, I will try checking the tail lights later.
Old 08-04-2012, 12:15 AM   #5
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Reverse parking sensors, i dont think is factory option like Scott mentioned. If it's aftermarket, try to find the wire or ask previous owner.
caineroad is offline   Reply With Quote
Rattle - Noise when Yaris put in Reverse Jungle Rot DIY / Maintenance / Service 14 08-27-2015 06:32 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 05:14 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Reverse gear crunch Frankd1 DIY / Maintenance / Service 5 04-13-2009 12:43 PM
