Old 08-04-2012, 07:39 PM   #1
Ot_tO
Drives: Look Signature... ;-)
Question yellow fog lights for Yaris 3dr 2009-2011
Hi ,
I'm searching yellow fog lights for my car (signature )...
No yellow bulbs or yellow adhesive foil!
The yellow fog lights need an *E* certification or at least a *SAE/DOT* certification.
I searched the web, but found to now no lights with.
Thanks.
Best regards!
YARIS II (XP9F) Facelift (2009-2011) 3dr Executive 1.33 (74kW/101PS/99hp) 6gear-MultiMode Jan/2010 (german version)
Ot_tO is offline   Reply With Quote
Old 08-04-2012, 07:51 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I've got a pair of yellow lens lamps if you can buy a kit that's sae) /dot approved you can swap the lamps on and it will still say its certified, no one would know the lamps are any different.
I say this because I think its hard to find any fogs with the actual lens being yellow. Typically you see the vinyl covers or bulbs but with clear lenses unless on eBay. And those are typically cheap and I don't think they have any certification.
Old 08-08-2012, 11:15 PM   #3
Ot_tO
Smile
You mean on the lamp (headlight housing) stay the certification?
But in Germany on the glass must stay *E*, or at least *SAE/DOT*.
...so that the police officer or the man at the TÜV see easy if they are street legal.
Just curious...
The pre Facelift (2006-2008) fog lights could be installed also at the Facelift (2009-2011) YARIS 3dr?
I mean - just the lamp (headlight housing)...
Not the black plastic around that it's look fine in the bumper. This is different between pre FL and FL...
Thanks.
Best regards!
Old 08-09-2012, 10:51 AM   #4
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
yellow fogs are old fashion fyi
caineroad is offline   Reply With Quote
Old 08-09-2012, 11:28 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Really? more like an opinion than information.
-Derrick-
Old 08-09-2012, 12:29 PM   #6
Ot_tO
Smile
It shouldn't be a cosmetic thing...
You drove one time with yellow fog lamps through fog, heavy rain or snowfall in darkness?
You will be surprised how much you will see with yellow fog lamps...
I had this at the previous car... - and I want this also at my YARIS...
In the headlamps I have already *NARVA Contrast+* H4 bulbs.
This are the only bulbs which have little bit more yellow and they are street legal (*E* certification) in Germany.
Best regards!
Old 08-09-2012, 06:05 PM   #7
1.5
Form>Function
1.5's Avatar
That's what I've got sorry it's sideways but look on the right hand side you can see it says sae/dot.
Old 08-11-2012, 07:25 AM   #8
1.5
Form>Function
1.5's Avatar
In fog housings or just any HIDs?
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
PIAA H11 Yellow Halogen Bulbs for Fog Lights Benggolf2 Cosmetic Modifications (Exterior/Interior) 6 10-02-2009 09:01 PM
