Old 08-09-2012, 11:38 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Another header thread...
I recently received my Weapon-R header. I am going to heat wrap it and silicon seal it before installing it. My progress will be slow.
I will say that my wrapping is a little less than "professional". I think I will keep my day job.
Heat wrapping...
I soaked the wrap so it would be more malleable. I am waiting for it to dry before I hit it with the silicon.
Old 08-10-2012, 01:01 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I like header threads.
Looks like you did a reasonably neat job considering that particular header is a difficult complex shape to wrap... and those are really nifty stainless retainers.
(by the way, you have a very cute little daughter. )
Old 08-10-2012, 08:06 AM   #3
BEEF
BEEF's Avatar
I think it would have wrapped much better if it were the 3 foot long beasts that you see on some of the old v8s. it was tight and finicky. I ended up getting the stainless steel wire ties from ebay. I didn't like the idea of paying $10 for 4. I got 25 for around $15 or so.
my daughter is awesome. she said "this is daddy's toy"
Old 08-10-2012, 09:55 AM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
really nice header. That wrap job came out pretty good too. Love my ceramic coated DC
Old 08-10-2012, 11:00 AM   #5
As long as it keeps the heat in, right?
No one can see it back there.
Old 08-10-2012, 01:36 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i tried to wrap mine...i got three rotations of wrap in & said fuck it...i have very little patience for stuff like that (suprisingly)
i may perhaps consider getting it swain coated
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-10-2012, 02:58 PM   #7
BEEF
BEEF's Avatar
I checked with swaintech and they wanted $250 to coat it (not including shipping). a friend of mine got a long tube header for a chevette and had it done. he recommended them but I couldn't see paying that kind of money for it.
Old 08-10-2012, 03:08 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
So Garm you ever think were going to see long tubes for the Yaris?
Old 08-10-2012, 03:31 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I would suggest getting the header exhaust kit from Micro Image.
http://shop.microimageonline.com/ARP...t-ARP-ems1.htm
Get the 45mm kit the flange on aftermarket headers tends to be thick and these studs work great and allow for easier instillation, the bottom middle bolt is a trick to get to, at least on the Megan Racing header it is.
Old 08-10-2012, 05:39 PM   #10
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Thats is nice!! Where dinyou bought this wrap and silicone ?
Interior:ALL red, black roof
Old 08-10-2012, 08:44 PM   #11
BEEF
BEEF's Avatar
I got it from here: http://www.designengineering.com/
someone on the MI forum recommended them. they have a dotted line that shows where to overlap. I did a really crappy job of the overlapping. it's a really funny shaped header.
http://www.designengineering.com/cat...ps-accessories
looking back, you could probably get away with the motorcycle exhaust wrap kit. I bought a 50 foot roll of the 2" and have over half of it left.
Old 08-10-2012, 08:53 PM   #12
1.5
Form>Function
1.5's Avatar
Beef I think you're understating your wrap. It came out really good and looks well coated IMHO.
Now enjoy that midrange grunt
Old 08-10-2012, 09:03 PM   #13
BEEF
BEEF's Avatar
@1.5
thanks, I hope you're right. I still need to silicon seal it. then get time to actually put it on the car.
Old 08-10-2012, 09:25 PM   #14
1.5
Form>Function
1.5's Avatar
The install is fun, its not "hard" by any means but its in an awkward position so it can get annoying at times. Being under the car working in a tight spot with your arms reaching up...
Old 08-11-2012, 08:18 PM   #15
CoryM
Drives: 2009 5-door, 5-speed
As someone who has done header wrap; Good job!
I always start off with grand visions of perfection, then end up with crap.
Not much use for you, but some people use high temp paint on the wrap after instead of silicone spray. It adds the colour back and seals it. I will be doing this on my other car but it's exhaust is a *little* more visible than on a Yaris (headers stick out the sides of the car )
Old 08-15-2012, 08:56 PM   #16
BEEF
BEEF's Avatar
I silicon sealed the header. I did some spraying and hit it with the torch.
Pre-silicon
Post-silicon
Old 08-15-2012, 09:00 PM   #17
1.5
Form>Function
1.5's Avatar
Very nice, I like it looking darker.
Old 08-15-2012, 10:12 PM   #18
tooter
play every day
tooter's Avatar
I do too.
The dark color complements the unusual contours of the header. Now don't ding it up when you install it!
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
