Old 08-12-2012, 06:58 PM   #1
BLITZEN
Drives: 2008 yaris rs
Exclamation Hi-beam as a DRL ? HOW TO ?
hello, my question is, it is possible to put the DRL on the Hi-beam ?
Note: I have projector low-beam separate than my hi-beam, and actually my DRL are on my low-beam's !
here pics:
Start up, hand brake up
Start up, hand brake down, DRL's on
Start up, hand brake down, Low-beam Lights on
Start up, hand brake down, Hi-beam lights on (they cut low beams light ??)
BLITZEN is offline   Reply With Quote
Old 08-14-2012, 12:28 AM   #2
BLITZEN
Anyone having trying this be4 ?!?
Old 08-14-2012, 10:28 AM   #3
I keep forgetting which beam really gets fired by the DRLs. For ages people have mentioned the highs being the ones that the DRL module feeds. As you found out, and as I now remember looking more closely at the EWDs it is actually the low beam that it pulses.
I haven't actually tried it, but I believe that If you wanted to have your high beams be the DRLs, then you could simply cut the large blue wire in pin 1 of the DRL connector, cap off the harness side and run a wire from the connector side of the wire to the negative lead of the high beams (and have the positive lead of the high beams connected to the constant +12 V pin on the headlight connector).
Old 08-17-2012, 11:46 PM   #4
BLITZEN
Ok ! But where is the negative lead of the high beams !?
Under the dash or under the hood?
Thx
Old 08-18-2012, 09:29 AM   #5
Thx
The pink wire on the headlight stalk connector on the steering column.
Old 08-19-2012, 06:29 AM   #6
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Would'nt your permanent high beams be rather inconvenient to oncoming motorists who are probably going to be constantly flashing their high beams at you.?
Have Yaris will travel..
Old 08-19-2012, 07:37 AM   #7
He's talking about having the DRL module drive his high beam bulb as the DRL. It is pulsed by the module, so it runs at about 1/2 brightness.
Old 08-23-2012, 04:05 PM   #8
BLITZEN
Ok thx , i'll do it !
But one last question: where is the positive lead of the high beams connector (meas what is the color of the wire) and for the constant +12 V pin headlight connector too?!?
Big thx
Old 08-23-2012, 04:39 PM   #9
Big thx
On the headlight connectors the black wire on the right headlight connector and the grey on the left is the positive. The headlights get a constant +12V feed and then the headlight switch switches the ground for the high or low beam filament to make one or the other light up.
Old 08-23-2012, 05:00 PM   #10
BLITZEN
So i need to cut and plug the black OR the grey wire on witch wire ??
Sorry mate am not electrician :(
Old 08-23-2012, 05:32 PM   #11
Since you have two separate bulbs, instead of one bulb with two filaments, you need the leave the black and grey hooked up to the low beam bulbs, but disconnect both from the high beam bulbs.
Old 08-23-2012, 09:02 PM   #12
Here the pic of the connector (head beam)(yaris 2008 rs):
plz show me the diagram !
big thx
That's the headlight switch connector. The connectors with the grey and black +12V wires are the two headlight bulb connectors.
The diagrams are in the electrical wiring diagrams, which you can download from the Micro Image forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 08-25-2012, 12:29 AM   #13
BLITZEN
Ok what i do its:
1-cut the blue wire from drl module
2-run a wire from the blue wire (drl module side)
3-tap in (didn't cut) the pink wire (connector headlight switch)
4-disconnect both side hi-light bulb 12v wire.....why should have needs to cut the wire who run +12v, if we needs constant +12v ?? What we gon do, Run the wire directly on the battery !???
I've doing that last time, except with the numb 4, and its work but the hi-light blinking as hell when i drop off the hand brake loll!
What can i do now ?
Big thx for helping
Old 08-25-2012, 03:14 PM   #14
Ok what i do its:
What can i do now ?
Big thx for helping
Are the high beams on your headlights HID's or are they regular bulbs?
Old 08-25-2012, 03:53 PM   #15
BLITZEN
Hi beam light in the head light kit are H1 bulbs
And when the drl was on low beam (H1), the bulb didnt flick.
Dimmed high beam as DRL? Ot_tO Cosmetic Modifications (Exterior/Interior) 5 08-21-2012 12:34 AM
DRL: Low beam or -lamps - or not? Ot_tO General Yaris / Vitz Discussion 10 07-27-2012 07:11 AM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
