Old 08-16-2012, 06:58 PM   #1
vinojcosta
Drives: Yaris 2008
Yaris Issue-2008
Can anyone help me I have a Yaris Hatch 2008 GCC spec, my ABS light doesnt come in dash when Im going to start the car, whats the problem
vinojcosta is offline   Reply With Quote
Old 08-16-2012, 07:23 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The ABS light only comes on when there's something wrong with it I think
Old 08-16-2012, 09:33 PM   #3
CoryM
Drives: 2009 5-door, 5-speed
ABS lamps should come on when first started as a bulb check. Stays on for a few seconds then turns out. Silly question, but are you sure your car has ABS? Many don't
Otherwise it's possible the bulb is just burnt out (or missing. Sometimes people remove the bulb to hide a problem when selling). I would first confirm the car has ABS, then check for codes (if car was bought used), then remove cluster and inspect bulb.
Cheers.
Old 12-04-2013, 02:25 PM   #4
vinojcosta
Drives: Yaris 2008
ABS light problem
Yeah I have abs in my car, the doesn't come on even the first time and Once I tried to break hard in a gravel road still doesn't work.
Old 12-04-2013, 02:31 PM   #5
Verify that you really have ABS by looking for the ABS pump an ECU below the brake master cylinder. If it is there there will be short metal pipes that connect it to the master cylinder and it will have a large connector (about 3 inches by 1.5 inches) plugged into it.
The instrument cluster gets the information over the CAN bus from the ABS ECU, so even if the ABS ECU was present and bad the cluster would still light the light for a second when the ignition is switched on, and if it doesn't send messages to the cluster once the car is running it will keep the ABS light on.
Old 12-05-2013, 12:21 PM   #6
vinojcosta
Drives: Yaris 2008
Thank you guys let me check on that,
CONSUMER REPORTS : March issue : 2010 YARIS sedan Hershey General Yaris / Vitz Discussion 41 02-18-2011 03:41 AM
Difference between 2007 and 2008 Yaris? wihed General Yaris / Vitz Discussion 5 01-02-2011 08:20 PM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
