Old 08-18-2012, 03:45 PM   #1
bronsin
bronsin's Avatar
PO300
I have a 2000 ECHO with a PO300 error code.
Can someone advise what to check for? I looked it up and it sounds complicated.
The vacuum lines all appear to be good.
Old 08-18-2012, 08:15 PM   #2
clarenceie
Drives: Yaris Sedan
I believe the code was P0300, which states multiple misfire. Does your engine feel like it's running weird? Not smooth?
clarenceie is offline   Reply With Quote
Old 08-18-2012, 08:50 PM   #3
bronsin
bronsin's Avatar
Runs normal. Mileage was down to 30 from ~34.
Old 08-18-2012, 10:01 PM   #4
That is one of those codes that can have a bunch of causes:
- Open or short in engine wire harness
- Connector connection
- Vacuum hose connection
- Ignition system
- Injector
- Fuel pressure
- MAF meter
- ECT sensor
- Compression pressure
- Valve clearance
- Valve timing
- PCV valve and hose
- PCV hose connections
- Air induction system
- ECM
