Old 09-17-2012, 08:41 AM   #1
matti
Drives: 2017 Yaris L (5sp manual)
Coasting in neutral vs. DFCO?
I've been using DFCO as much as possible in my 2012 Yaris L (5-spd) as I realize it's an easy way to reduce some fuel consumption. I came across an ecomodder.com website that gives fuel-saving tips:
http://ecomodder.com/forum/EM-hyperm...ecodriving.php
#44 on the list states that coasting in neutral (with engine idling) is a better option than coasting in DFCO mode. I was under the impression that DFCO was better than coasting in neutral? Any thoughts? Thanks.
matti is offline   Reply With Quote
Old 09-17-2012, 08:57 AM   #2
It's a juggling act using both DFCO and neutral to achieve best results.
If using DFCO slows you down too quickly and you end up needing to apply gas sooner than desired, then you've lost some of the gain.
Old 09-17-2012, 01:01 PM   #3
NEexpat
Drives: 2009, auto, 4dr LB
If I had a 5 speed I'd be tempted to bump that thing into neutral every chance I got. Since I have the auto I'll stick with DFCO.
My car before my Yaris was a 1988 honda Accord LXI 5 speed, and I could squeeze 36 mpg in the summer 32 mpg winter. The gas tank was 15.9 gl. Which put its range out past 550 miles in the summer.
I think that car spent more time in neutral than in gear. Of course that was an 80's car, no DFCO.
NEexpat is offline   Reply With Quote
Old 09-17-2012, 06:49 PM   #4
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
if you put it in neutral with automatic transm. would it be ok to change it to Drive while moving ?
new-yaris-owner is offline   Reply With Quote
Old 09-17-2012, 09:00 PM   #5
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Personally .. I wouldn't be messing with an Automatic transmission much ... as in order to save yourself a few bucks in gas, you may wreck a very expensive transmission. Standard transmissions are a different animal.
If I had an automatic transmission .. I would take my foot off the gas and use DFCO as much as I could but leave the car in gear to lessen the wear on the transmission.
edmscan is offline   Reply With Quote
Old 09-18-2012, 01:40 AM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'd do the same if I had an auto trans, because the fluid coupling allows the engine to slightly "freewheel" while in the highest gear. Add that to DFCO and mileage is going to go up.
I don't coast in neutral with my stick because when the engine is idling it's still using gas, whereas coasting in gear raises the engine rpms above idle and activates the DFCO. Then it doesn't matter how fast the engine is turning because it's not using any gas anyways.
Just stick it in 5th and put both feet on the floorboard.
Old 09-18-2012, 10:40 AM   #7
matti
Thanks everyone. I think I'll just continue to use DFCO vs. putting it in neutral while coasting.
Old 09-18-2012, 01:59 PM   #8
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Unless I'm planning on slowing down or coming to a stop, I prefer to neutral coast. It has given me the best MPG results.
goliath1812 is offline   Reply With Quote
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 04:15 AM
Kinetics, coasting, and you sbergman27 Fuel Economy Forum 18 05-08-2010 01:25 PM
Coasting in neutral bankrobber Fuel Economy Forum 9 03-11-2010 03:55 PM
2004 yaris hatch, 2nz-fe, DFCO in all gears? toyo Fuel Economy Forum 11 06-26-2009 02:21 PM
So Close!!!! aclark246 Fuel Economy Forum 13 06-07-2009 10:02 AM
