Old 09-19-2012, 12:25 AM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Question Need help with sub/amp setup
I gotta 12 inch sub that has:
200 watt RMS
400 watt peak
Single 4 ohm Voice coil
It's gonna be in a sealed box also. My issue is how big of a amp will I need? Lookin for something that'll work w/o blow up lol
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 09-19-2012, 04:48 AM   #2
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
You could tell us what brand/model it is. That would be helpful.
What size sealed box you going with?
Old 09-19-2012, 07:31 PM   #3
Qmobile
Qmobile's Avatar
Directed is the brand my sub is from it's eXtreme line model number 124SX. the box i'm not sure of the size but it's just a generic Scosche 12" box
Old 09-19-2012, 09:15 PM   #4
Alien Mantis
Secret Agent
You need something like this:
http://www.sonicelectronix.com/item_...GM-D7500M.html
Old 09-19-2012, 11:09 PM   #5
Qmobile
Qmobile's Avatar
ok any other options?
Old 09-20-2012, 12:46 AM   #6
Qmobile
Qmobile's Avatar
what's like the least amount of watt I'd need? I can get a 200 watt for cheap is why I'm askin
Old 09-20-2012, 02:29 AM   #7
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Price range ?
Old 09-20-2012, 02:37 AM   #8
Qmobile
Qmobile's Avatar
nothing too expensive >$100
Old 09-20-2012, 03:01 AM   #9
Alien Mantis
Secret Agent
You could go with this one, but you can't crank the gain.
It makes a little more power.
http://www.sonicelectronix.com/item_...KAC-8105D.html
Old 09-20-2012, 03:05 AM   #10
Alien Mantis
Secret Agent
I don't recommend BOSS, SSL, JENSEN, HiTron, Power Acoustik, etc.
Cheap amps tend to run hot and they don't last. They also produce dirty power.
Class D is nice for subs, and those amps are all a little over $100.
Buy a Boss or SSL for $70. Nothing stopping you. It should technically "work".
But most people on here won't recommend it.
So here ya go, if this is what you want:
http://www.sonicelectronix.com/item_...s-CX1100M.html
Old 09-20-2012, 03:14 AM   #11
Qmobile
Qmobile's Avatar
well there is some wiggle room 2 I like that kenwood. But back to my what's the least amount I'd need to push the sub?
Old 09-20-2012, 10:31 AM   #12
willygoodness
Drives: 09 yaris hb
any brand that says output of 200rms @4ohms and you'll be fine and i'd say happy with.
if u don't want to put the volume button up to full on the amp. get a 300wrms @4ohm amp.
if u get a 2ohm or a 1ohm @200rms amp, it won't sound as clear. as the sub is for 4ohm.
i've got 2x 4ohm subs. but if i run both off the same amp at 2ohm it gets louder. but not as clear... if that helps u
just don't turn up the subsonic bass knob, that's IMO the thing that blows subs
http://www.ebay.com.au/itm/NEW-VSA-C...item1e6a5660da
had one for over a yr and still works with rough install
willygoodness is offline   Reply With Quote
Old 09-20-2012, 10:53 AM   #13
_S7V7N_
_S7V7N_'s Avatar
Don't ever use the Gain/Level knob on an amp as a Volume. When i get to a computer later on i'll post some info Qmobile. Alot of the feedback you have received is False.
Here's an ok amp with room to grow. Would i buy it. No because i can get about Tripple the Power for that price. I wouldn't recommend the amp i use because it isn't efficient for a newbie (no offense). The amp kit you'll need will cost about 60 bucks. Upgrade your battery. Big 3. So you're looking at about an additional 200 bucks.
So to be efficient on your battery i'd stick with the Best Buy brands. Which is "okay". Kenwood , Fosgate , Alpine, Pioneer.
http://item.mobileweb.ebay.com/viewi...id=32887707894
Old 09-20-2012, 01:54 PM   #14
Qmobile
Qmobile's Avatar
ok thanks! I'm lookin to get a MEI DA8275 300 watt amp 2 channel 4 ohm amp. Know anything bout that one?
Old 09-20-2012, 04:27 PM   #15
_S7V7N_
_S7V7N_'s Avatar
Amp is Probably about 15 years old ? MEI hasn't been around for a while.
Amp probably does 75 watts RMS
15 bucks at the most for that amp. Same category as Jensen or Boss.
Old 09-20-2012, 05:17 PM   #16
Qmobile
Qmobile's Avatar
ok I thought it was 2 good 2 be true. The guy is askin $35 for a amp from '95 seemed a bit extreme 2 me
Old 09-20-2012, 06:07 PM   #17
Alien Mantis
Secret Agent
Hey Seven,
He doesn't have to do the big3 upgrade. He's runnning a low power system.
He asked what is the minimum power he needs for that sub he has.
I would say 150watts RMS at 4ohms.
An 8ga amp wire kit will work fine for that.
Old 09-20-2012, 06:28 PM   #18
Qmobile
Qmobile's Avatar
So Alien Mantis,
the MEI amp what's your view on it?
Sound System Setup ronan4210 Middle East 59 01-28-2012 11:59 PM
)) Steering wheel hub setup (( aucorium Cosmetic Modifications (Exterior/Interior) 4 04-30-2011 04:09 PM
6 speaker setup and speaker sizes jstantherprsn DIY / Maintenance / Service 0 12-09-2010 11:21 AM
anyone wanna sale there turbo setup for $1000 1.5ty Willing to Buy by private party 0 06-02-2010 02:51 AM
New "milder" Setup Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-26-2010 10:08 AM
