Old 09-19-2012, 02:29 PM   #1
ThomEdwardDudgeon
Chainsaw
Drives: 2012 Yaris Sedan
Moving non-telescoping steering column up safely
To gain easy access to the steering column, just unpop the plastic center panel below the column. It's held in place with piano hinges, opens downward like a bin door. Take out the 3 screws that hold the flimsy plastic cover (2 pieces) onto the column itself and move them aside. Now you have access. Let the column down with the handle, use a 12mm socket and a 6" extension, undo the nuts holding the clamp bracket in place. Move the column up and down and see the column stops where the washers and plastic guides "top out" against the dashboard form. Pull the washers and their plastic guides straight out, push the column up and reinstall the nuts-there's metal spacers coming off the bracket that serve as washers. You'll gain about 1/4", but we're talking angles, so being 6'2", it moved the column up more than enough for me, even with extra foam beneath the front of the seat and I was glad I didn't have to do any major mods that may compromise safety. If I haven't explained anything clearly enough, feel free to respond.
ThomEdwardDudgeon is offline   Reply With Quote
Old 09-21-2012, 07:44 AM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
The information is very useful. I also did not have enough flight steering column.
If you take a photo it would be very useful.
I like very much travel
MickZEL is offline   Reply With Quote
Steering column compatibility between Euro Yaris and US Yaris Micropurchase Third Gen Yaris General Discussion 19 09-17-2012 12:00 PM
Telescopic steering column extension length? Micropurchase Australia 3 05-27-2012 03:38 AM
WTB: Yaris 05-07 NON ABS Steering column assembly + Electric Steering ECU (part out?) vitriumgts Willing to Buy by private party 8 10-06-2011 04:13 PM
Yaris Hubcaps, Wheels And Steering Column potorap Items for Sale by private party 11 11-17-2010 06:07 PM
WTB: Steering Wheel Column Nexus1155 Items for Sale by private party 0 09-03-2007 06:04 PM
