Old 09-24-2012, 12:55 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Blitz Oil Cap o-ring
Haven't got an answer at MI yet, so I thought I'd check with you guys.
Is the o-ring on the Blitz oil cap supposed to come off so easy? It seems like when you remove the cap it will just fall off into the engine bay somewhere. The factory oil cap has the O-ring built into the cap or it's held in somehow. The one on my Blitz cap just sits in a track with seemingly nothing to prevent it from just falling off at any given time.
Old 09-24-2012, 12:56 PM   #2
47_MasoN_47
Come on I've seen these in engine bay pics around here. Someone should be able to tell me if this is the way it's supposed to be and how you are supposed to deal with it.
Old 09-24-2012, 01:08 PM   #3
I have the TRD one and the o-ring is tight around the base.
Old 09-24-2012, 01:28 PM   #4
47_MasoN_47
Should/could I just glue the o-ring into that track that it sits in? It's weird that it's setup that way. Doesn't really make any sense.
Old 09-24-2012, 01:51 PM   #5
TRDMarty
You have 2 options
1) Remove the o-ring off of your original oil cap and install on Blitz cap
2) Remove the o-ring off of your original oil cap and measure size then
look up McMaster Carr website catalog under o-rings (BUNA-N type) and order.
Its to bad you're not closer to me cause I have EVERY size o-ring there is
in my test lab at work (Aerospace) and I would gladly donate a couple to you.
Best of luck
Old 09-24-2012, 04:03 PM   #6
Franklin's Hardware has all kinds of O-rings in their plumbing department. You probably have a hardware store near you as well?
Old 09-24-2012, 04:35 PM   #7
47_MasoN_47
So getting an O ring that fits snugly in there is the best way to do it?
Old 09-25-2012, 02:07 AM   #8
^ I would say so, yes. I think it's supposed to fit better!
Old 09-25-2012, 07:19 AM   #9
or clean it up and try gluing it in with some black RTV silicon
Old 09-25-2012, 10:37 AM   #10
47_MasoN_47
Ok thanks :) I'll see what I can find.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
