Old 09-24-2012, 06:51 PM   #1
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
Failed CA Smog Check
The HB failed the CA Smog Check because the system says "Failed Purge Flow". Is that the purge VSV?
Fidelio is offline   Reply With Quote
Old 09-24-2012, 08:17 PM   #2
Yes - That is still the P0441 DTC.
Old 09-24-2012, 09:32 PM   #3
Fidelio
EcoFriendly
Fidelio's Avatar
Hey Scott -
Do you know if these Purge VSV are the same all across the compact and subcompact cars for Toyota? Corolla, Matrix, and Yaris? I'd guess the majority of these parts are interchangeable?
Stephen
Old 09-24-2012, 09:53 PM   #4
Originally Posted by Fidelio View Post
Hey Scott -
Stephen
For whatever reason, the Yaris one is specific to just the Yaris. The part number is: 25860-21090.
Old 09-25-2012, 02:49 AM   #5
Fidelio
EcoFriendly
Fidelio's Avatar
okay i replaced it. Should the code reset on its own?
Old 09-25-2012, 07:39 AM   #6
You will have to reset it manually.
Old 09-25-2012, 08:57 AM   #7
barryware
dunno how it works in CA.. But here in Illinois, they will bounce your car if it has not been driven long enough after the code reset. I do not know how long that is.
I don't know about toyota, but GM will give a "not ready" after a code reset for some time.
barryware is offline   Reply With Quote
Old 09-25-2012, 10:52 AM   #8
Fidelio
EcoFriendly
Fidelio's Avatar
I think my mini OBDii resets codes. Ill check. The last time what I did to reset the code was unplug the battery and left it unplugged overnight. Is that not another method?
Old 09-25-2012, 12:22 PM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I thinkn 5-10 minutes should be enough for the battery pull
Old 09-25-2012, 12:25 PM   #10
Battery pull (5 minutes) definitely works for resetting of that DTC.
Old 09-25-2012, 05:42 PM   #11
Fidelio
EcoFriendly
Fidelio's Avatar
Yep the mini OBDii has an erase button. I erased the code this morning. It hasnt turned on since then. Is there a way to make sure it's not failing? I average about 14-20 miles every 3-4 days. I dont really drive much. If I need to I ride my bicycle within a 10-12 mile radius.
Old 09-25-2012, 05:49 PM   #12
Again, that test only gets performed after you have driven for more than 10 minutes and then shut the car off for more than 6 hours. If you have ever walked by your car after it had been sitting for the better part of a day and heard it making a buzzing sound, then that was the test happening.
Old 09-25-2012, 09:21 PM   #13
Fidelio
EcoFriendly
Fidelio's Avatar
hmmm so today I drove 40 minutes and left the car parked for about 5 1/2 hours then drove off again for about 20 minutes. Should that have triggered the sensor if working or non-working? so far no check engine light.
Old 09-25-2012, 09:31 PM   #14
No. 6 hours off is the minimum to trigger the test.
Old 09-26-2012, 12:26 PM   #15
Fidelio
EcoFriendly
Fidelio's Avatar
So far no check engine since the night before day and yesterday. I borrowed this purge VSV from a friend that has the 2009 sedan version. His check engine did turn on using my Purge VSV so at least I know that my purge VSV is the problem.
Now it's a matter of finding the part either on ebay or at a salvage yard unless someone on the board has a working spare.
Thanks for all the input.
Old 09-26-2012, 07:26 PM   #16
Fidelio
EcoFriendly
Fidelio's Avatar
cool, switching the part passed smog. Now I need to find my own working purge VSV.
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
first fix-it ticket yrsdrgn California 44 07-03-2007 06:31 PM
